FAQ: How do I read Spoon/Toda Gen 2 Cam Gears?
Old Jun 1, 2004 | 09:28 PM
B2FiNiTY's Avatar
Default FAQ: How do I read Spoon/Toda Gen 2 Cam Gears?
Was doing a valve adjustment on my friend's motor and he asked me how to read his gears. on me because I had no clue how.
What is this gear set at?
Old Jun 1, 2004 | 09:31 PM
esponet's Avatar
its advance, not sure 2 or 4 degrees.
but anyways, the middle dot is 0, linning up the line to the left or to the right adanaces or retards it. 1 or 2 degrees. not sure how much.
i will look for my sheet that came with my todas. and let you know tomorow.
Old Jun 1, 2004 | 09:35 PM
B2FiNiTY's Avatar
Default Re: (esponet)
If you can post the sheet or someone else, that would be great! I remember a thread with it but can't find it.
Searched and found dead threads:
https://honda-tech.com/zerothread?id=744192
https://honda-tech.com/zerothread?id=376628
Old Jun 2, 2004 | 12:16 AM
TypeR 599's Avatar
oo those gears are soo pretty. damn rusty *** juns.
Old Jun 2, 2004 | 03:23 AM
Willard's Avatar
Default Re: FAQ: How do I read Spoon/Toda Gen 2 Cam Gears? (B2FiNiTY)
looks to be almost at zero.
vernier scales are fun to read.
from the toda web site.
• The graduations are the same as thoughts found on a vernier caliper, where in adjustments can be carried to 1 deg of the crank angle.(0.5 deg of the cam angle)
Old Jun 2, 2004 | 06:46 AM
geometro's Avatar
Default Re: FAQ: How do I read Spoon/Toda Gen 2 Cam Gears? (Willard)
I would have to concur, it looks like zero, but due to parallax, it looks like its at 0.5deg...
Vernier scales rule.
George
Old Jun 2, 2004 | 07:00 AM
baonest's Avatar
Default Re: FAQ: How do I read Spoon/Toda Gen 2 Cam Gears? (geometro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">looks to be almost at zero. </TD></TR></TABLE>
i too see ~ zero
Old Jun 2, 2004 | 07:28 AM
JDM CTR '00's Avatar
Default Re: (TypeR 599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">oo those gears are soo pretty. damn rusty *** juns. </TD></TR></TABLE>
Atleast you don't have a problem with reading yours lollll Maybe you do with the rust? lolll
Old Jun 2, 2004 | 08:00 AM
sneakychaos's Avatar
Default Re: (JDM CTR '00)
looks to me like 3 degrees, too.
Old Jun 2, 2004 | 08:03 AM
Default Re: (sneakychaos)
For further reference, courtesy of Godspeed:
http://www.godspeedinc.com/camgeardirections.html
Old Jun 2, 2004 | 09:54 AM
TypeR 599's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR '00 &raquo;</TD></TR><TR><TD CLASS="quote">Atleast you don't have a problem with reading yours lollll Maybe you do with the rust? lolll</TD></TR></TABLE>
You act like yours aren't rusted
Old Jun 2, 2004 | 10:00 AM
tell you the truth they are not. they look brand new
unknown0001's Avatar
sorry for this newbish question...but what improvements/gains will you notice when you advance your cam gears????
Old Jun 2, 2004 | 12:45 PM
AzG35's Avatar
Its 2 degrees advanced. These gears read just like the STR's. Go from the center, count how many degrees you want to advance or retard.
Start from the outside, count notches of how many you want to move.
Go to the inside, count the same number.
Match the outside notch with the inside notch and you're done.
Old Jun 14, 2004 | 04:55 AM
MugenB16A2's Avatar
Looks more like 3 degrees advanced to me. IMHO.
elmy eg6
11
Jun 1, 2009 08:57 PM
EG69
Jun 20, 2007 08:37 AM
MugenB16A2
69
Jun 17, 2004 07:22 PM
Nate B
Nov 25, 2002 10:04 AM
SpoonFed
Feb 15, 2002 11:19 PM
