Removing pinstripes
Old Jun 1, 2004 | 09:23 PM
fubar's Avatar
Default Removing pinstripes
I have a black 99 Prelude that has pinstripes and I would like to remove them. Can you remove the pinstripes easily? When I bought the car I had removed the "dealership sticker" they put on the car by heating it up with a hair dryer...could I do the same with the pinstripes? The only problem I think would be that you may be able to see where the pinstripes once were after they have been removed, as I just bought the car this past December, so the pinstripes could have be on the car for 5 years...
So, has anyone done this before or have any important info I should know before I attempt removing the pinstripes?
Thanks in advance.
Old Jun 1, 2004 | 09:26 PM
Kal's Avatar
Kal
Default Re: Removing pinstripes (fubar)
You want to use the blowdryer to heat up the glue and pull the pinstripe flush against the car (helps remove the glue) and keep pulling. Then use googone to remove the rest of the glue residue.
Old Jun 12, 2004 | 04:00 AM
SearchBeforeUPost!'s Avatar
Default Re: Removing pinstripes (blackdc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc5 &raquo;</TD></TR><TR><TD CLASS="quote">
Would this apply to stickers in general? I have a front lip w/ a JsRacing sticker on the corner...I bought it used a LONGGG time ago and it's bugging me enough now to make me want to take it off. The only problem is, I didn't think it would be possible since it's been on the lip for so long. Is there a way to take it off w/o damaging the paint?</TD></TR></TABLE>
yes.
I removed my pinstripes from my 91 accord about 3 years ago. So that means they were on for 10 years. You can't tell the car ever had pinstripes now and it looks so much better!
Old Jun 12, 2004 | 05:00 AM
disabled's Avatar
Default Re: Removing pinstripes (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">You want to use the blowdryer to heat up the glue and pull the pinstripe flush against the car (helps remove the glue) and keep pulling. Then use googone to remove the rest of the glue residue. </TD></TR></TABLE>
i did it the same way worked fine for me only my pinstripes were old and they kept breaking up into little peices
Old Jun 12, 2004 | 06:14 AM
killa_lude's Avatar
Default Re: Removing pinstripes (disabled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by disabled &raquo;</TD></TR><TR><TD CLASS="quote">
i did it the same way worked fine for me only my pinstripes were old and they kept breaking up into little pieces</TD></TR></TABLE>
yeah thats how mine were, i couldnt even take them off in pieces....it was so bad. the car looks so much better though, but you can tell up close that the paint where the pinstripes were looks glossier.
Old Jun 12, 2004 | 12:28 PM
yOnKiNaToR's Avatar
watch it though; some pinstripes are actually glued or clear coated on at the tips..i know mine are and that's why i haven't tackled that project yet
Old Jun 12, 2004 | 01:42 PM
killa_lude's Avatar
yeah i just used my nails...it wont harm the paint. you can buy **** too that will take off pinstripes.
EKSedAndy
Jan 31, 2008 04:23 PM
gwiffer
12
May 16, 2007 07:24 AM
ekdriven
Mar 8, 2005 08:00 AM
Honda_18
25
Dec 5, 2004 02:38 PM
iam7head
Sep 25, 2002 07:05 AM
