code 20 anyone
car died at the track and know it wont start its flashin code 20 elecrtic load anyone know anything that can help me the headlights dont work and mostly everything else electrical like wipers and wut not on the bright side the horn works and the car will turn over but its not gettin fuel
first of all you should of check your codes. Code 20 is electrical load detector, so probably your ecu or some sensor plug might of came off and its unplug or maybe you have a defective sensor. check all you engine harness and all the plugs make sure is good and go from there.
good luck man
good luck man
nope thats not it the engine turns over and all but its not getting fuel and thehead lights dont come the dash fuse box wasnt getting any power either no loose connections in the fuse box all fuses are good to
