DSM Turbo Project
Old Jun 1, 2004 | 05:35 PM
h22mark's Avatar
Default DSM Turbo Project
Hey everyone, I am putting together a stock DSM turbo kit to put on my JDM F22B DOHC engine. I am just doing this for kicks, not for major power just a little extra for daily driving that IHE can't do for that motor. If any of you are doing this or have done this please chime in with your opinions.
Old Jun 1, 2004 | 06:12 PM
h22mark's Avatar
Default Re: DSM Turbo Project (h22mark)
I will also post up my findings and eventually a step by step of what I did, keep tuned for more updates.
Old Jun 1, 2004 | 06:14 PM
SKDRCR's Avatar
what kind of engine management are you going to use?
Old Jun 1, 2004 | 06:20 PM
h22mark's Avatar
Default Re: DSM Turbo Project (SKDRCR)
Most likely a hack program, I am still trying to source the parts...trying to make this a low-budget project, but there will be lots of time spent into it as well as dyno tuning.
Old Jun 2, 2004 | 10:47 AM
irishpilot's Avatar
for EM you can use the Uberdata and a wideband, or a Safc.
For the manifold- the 2nd gen manifold is better from what I hear, less prone to cracking and flows better supposedly
the turbo however off the 1st gen (14B)is better since flows more air or something.
you can use the bov off the 1st gen
both turbo's have an internal wastegate and go upto 12psi, so you have to tweek them slightly to get the wastegate to open sooner. 6-8psi
you can get a FMIC off a starion or conquest for reasonable amount of money.
You'll want to upgrade the stock fuel pump to a walbro or something. also, its smart to get the dsm injectors as well since they flow more fuel.
You'll def want a good EGT and Boost guage as well
for piping you can go with alum or plastic/pvc, yes I said pvc, someone said they used it and it worked very well, but it is hear say.
Old Jun 2, 2004 | 01:06 PM
h22mark's Avatar
Default Re: (irishpilot)
Cool sounds like you have done this already.
Old Jun 2, 2004 | 07:22 PM
irishpilot's Avatar
well, I was really considering it for a while and did alot of research on it. the only reason I didn't do it was because I dont have a second car and couldn't deal with the down time and getting to work and such. Also, people hate on the setup since the turbo doesn't flow enough air up high, so when going higher the powerband the HP.TQ wont be continuing to climb, it will fall on its face as so many put it.
But, the point of the project is to be cheap and ghetto. so as long as the boost is kept low then it should work great, especially for around town and such
Old Jun 2, 2004 | 07:34 PM
irishpilot's Avatar
heres a link to pics of the DSM turbo on a H23
http://www.imagestation.com/album/?id=4287803439
good luck with your project:bigthumb:
Old Jun 2, 2004 | 10:55 PM
red91sit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irishpilot &raquo;</TD></TR><TR><TD CLASS="quote">
for piping you can go with alum or plastic/pvc, yes I said pvc, someone said they used it and it worked very well, but it is hear say. </TD></TR></TABLE>
PVC is okay for low boost applications under not too hot of heat there is one person running it for a few years succesfully on a dsm turbo at about 8 psi but if it gets too hot it starts to mealt and releases toxic and bad for your engine fumes.
Old Jun 3, 2004 | 10:32 AM
h22mark's Avatar
Yeah thanks, I should have a second car but I am trying to finish before the end of summer so when I commute to college it should be ok. But at the moment no job and funds are depleting. But like I said I'll keep you all updated.
nihad
24
Jan 22, 2007 05:08 PM
silverboost
Oct 31, 2006 05:24 PM
Honda owner
Jun 3, 2006 04:03 PM
Scither69
Aug 8, 2004 03:12 PM
7808
Feb 13, 2004 04:33 AM
