dumb Golden Eagle lsvtec dowel pin question
Old Jun 1, 2004 | 05:27 PM
99B16Si's Avatar
Default dumb Golden Eagle lsvtec dowel pin question
does the thinner part go into the head or block?
i dont have them in front of me but it seems like they can go in either spot depending on what side is up and down.
my reasoning for a dumb question: if u put the dowels in the back of the head u put the skinny part in the head and the fat part in the block. if u put them in the front u put the fat part in the head and skinny in the block. it seems like both will work to me
Old Jun 1, 2004 | 05:32 PM
Kataku2K3's Avatar
Default Re: dumb Golden Eagle lsvtec dowel pin question (99B16Si)
Thinner goes to the head on the IN side of the motor.
Old Jun 1, 2004 | 05:34 PM
99B16Si's Avatar
they couldnt go the other way upside down?
Old Jun 1, 2004 | 09:37 PM
99B16Si's Avatar
ttt
Old Jul 16, 2004 | 08:50 PM
dat_flip's Avatar
Default Re: (99B16Si)
did you figure out how to put them in?
Old Jul 16, 2004 | 09:16 PM
wade's Avatar
Default Re: (dat_flip)
i just did this swap last week. U doing a LSVTEC?
Smaller side goes into block EXHUAST side. LArger part goes into head. then u must drill out the 2 dowel holes on the exhuast side of the gasket 9/16 to fit the dowel pin
ur done
Old Jul 16, 2004 | 10:38 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">i just did this swap last week. U doing a LSVTEC?
ur done</TD></TR></TABLE>
LOL
Old Jul 17, 2004 | 12:05 AM
leadfoot78's Avatar
Default Re: (wade)
I'm 99% sure there is no drilling necessary for the GE dowels. You only have to drill the head if your are using the stock dowels.
Old Jul 17, 2004 | 06:17 AM
99B16Si's Avatar
he said drill the gasket not the head and nobody has yet to answer my question...i know how to put in a friggin dowel pin. my question once again is:
can un install the dowel pins unside down on the opposite side(intake)????
Old Jul 17, 2004 | 06:25 AM
B18C1CYA's Avatar
i used a ge headgasket and did not have to drill any thing, i put my dowels in the exhaust side of the head for some reason they wouldnt work on the other side for me, i dont know if it had any thing to do with useing head studs or not, but it shouldnt matter where you put them aslong as they are there mine work fine in the exhaust side
Old Jul 17, 2004 | 07:36 AM
G
sh!t happens.
Default Re: (B18C1CYA)
im doing the build right now on mine.. would anyone have any pic. of them installed? do they go were the stock dowel pins were? and i never heard of anyone having to drill the headgasket to make them fit. i know you only have to drill when you use stock pins but not the ge or full race. i have full-race dowel pins
Old Jul 17, 2004 | 08:10 AM
99lsvtecauto's Avatar
Default Re: (G"UNIT)
u always have 2 unless u get a golden eagle headgasket which is just an oem that ge has done if already the dowel pins r 4 perfect aligment on the head but u have 2 open the open the gasket dowel a little to make it fit check diyracing.com teamintegra.com alot of site say the same thing even in the superstreet issue long time ago they did 2
Old Jul 18, 2004 | 01:06 PM
wade's Avatar
Default Re: (99lsvtecauto)
damnit, whatever i tried to help.
THROW away your damn stock doweles ok.
Take the GE dowels, place the small end on the EXHUAST SIDE OF THE BLOOOOCK! the drill the OEM headgasket dowel holes to 9/16 inch on the corresponding EX dowel matching hole locations. The larger end of the dowel goes into vtec head.
Old Jul 18, 2004 | 01:07 PM
wade's Avatar
Default Re: (wade)
dont do it on the INTAKE side, why do u insist on this when you arent suppose to ?
K20teggg95
Oct 22, 2011 10:41 AM
1POINT8L
Jul 22, 2008 07:19 PM
GetawayInMoscow
Nov 20, 2006 07:07 AM
LSEGHATCH
Aug 16, 2005 06:54 PM
93B17A
Jun 9, 2003 07:27 PM
