water or oil ????
Old Jun 1, 2004 | 12:54 PM
EF-21's Avatar
Default water or oil ????
My b16a is puffing smoke now so i check the spark plug for some reason. they where white as hell so i change them ran better. But it would still puff smoke when i push it hard like over 5400rpm. the oil is fine no oil loss at all my old man says it might be a head gasket leak. When i drive about 85 mph on 5th gear J1 tranny the cabin smells like the engine burning and more smoke thru the tail pipe so i slow down to 65 and the smell decrease then goes away. Also no vtec kicking in at all. What can i check, if its doom how much would a short block b16a run for. sad part i have only had it since febuary of this year
Old Jun 1, 2004 | 12:55 PM
96-EJ6 B18C's Avatar
Default Re: water or oil ???? (EF-21)
What color is the smoke? Compression test results...
Old Jun 1, 2004 | 12:56 PM
ComputerJLT's Avatar
yeah; compression/leakdown test asap.
Old Jun 1, 2004 | 01:11 PM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF-21 &raquo;</TD></TR><TR><TD CLASS="quote">My b16a is puffing smoke now so i check the spark plug for some reason. they where white as hell so i change them ran better. But it would still puff smoke when i push it hard like over 5400rpm. the oil is fine no oil loss at all my old man says it might be a head gasket leak. When i drive about 85 mph on 5th gear J1 tranny the cabin smells like the engine burning and more smoke thru the tail pipe so i slow down to 65 and the smell decrease then goes away. Also no vtec kicking in at all. What can i check, if its doom how much would a short block b16a run for. sad part i have only had it since febuary of this year </TD></TR></TABLE>
First thing is that you are running lean if your plugs are white.
what color is the smoke?
short block is $599 from here http://hmotorsonline.com/.
I got my motor from them and it literally runs like its new. 15K miles, not 1 problem.
Old Jun 1, 2004 | 01:13 PM
EF-21's Avatar
Default Re: water or oil ???? (roadawg)
my old man said blueish color
thanks roadawg $599 not bad because if it just cheaper than to f@@k with the engine ill save more money to buy one
what should the compressions be between cylinders
Old Jun 1, 2004 | 01:58 PM
EF-21's Avatar
i checked the tail pipe and u can smell the raw fuel and see the liquid form. i cahnge spark plugs yesterday and they where white. today i checked them and once again they are starting to turn white. what can this mean.
Old Jun 1, 2004 | 02:49 PM
EF-21's Avatar
bump
Old Jun 1, 2004 | 02:52 PM
roadawg's Avatar
blue smoke is oil burning
compression should be anywhere from 180 to 230 on average, but as long as the numbers are consistent you should be fine, whithin 10 psi from each other.
Old Jun 1, 2004 | 02:59 PM
EF-21's Avatar
thanks ill just race it hard till it blows
Old Jun 1, 2004 | 03:24 PM
Blaze45's Avatar
Brrraaaap!
Or just do a compression test and figure out if its a HG and save yourself a ton of money... There are kits that you can get that test the coolant for a blown HG...
Blaze
Old Jun 1, 2004 | 05:25 PM
EF-21's Avatar
Default Re: water or oil ???? (Blaze45)
checked my compression # 1 is 150 psi # 2 is 150 psi #3 is 170 psi #4 is 170 psi. Now the thing is is it the rings or the head gasket is their any other way to check.
i search and i made a mistake i didnot have WOT or pull the fuse to cut off fuel how much will it afect the results
Modified by EF-21 at 2:39 AM 6/2/2004
Old Jun 1, 2004 | 06:35 PM
if you dont have oil and coolant mixed in either the oil or coolant then its not your head gasket;
low compression is either caused by worn rings or improperly seating valve. get a leakdown test and you can find out more.
Longbow
Sep 25, 2011 12:18 AM
cetcivic
Jan 21, 2008 05:40 PM
Mike813
Mar 15, 2004 08:56 AM
QUICKERSILV3R
Dec 19, 2003 03:40 PM
cjohnson_2
Sep 8, 2002 05:33 PM
