91 honda civic si TPS on a b16a1?
Old Jun 1, 2004 | 12:44 PM
91_civicsi's Avatar
Default 91 honda civic si TPS on a b16a1?
can this work out, i found out my b16 tps is smashed for some reason or another and i dont know why
i searched for this issue, and i found that d series tps sensors worked for other ppl but someone said something abouit switchiing the outside wires? what does this mean
help would be appreciated, thanks
Old Jun 1, 2004 | 12:50 PM
96-EJ6 B18C's Avatar
Default Re: 91 honda civic si TPS on a b16a1? (91_civicsi)
The Si TPS will work fine on the B16...you can use a hack saw blade to notch the rivets that hold it on to the TB then unscrew them using a flatblade screw driver.
Old Jun 1, 2004 | 01:16 PM
91_civicsi's Avatar
Default Re: 91 honda civic si TPS on a b16a1? (96-EJ6 B18C)
i dont get it man??? isnt there something to do with swapping the wires,,, what you mean a hacksaw blade and chop rivets? and then flatblade// confused
why cant my b16 tps NOT be smashed :S
Old Jun 1, 2004 | 01:27 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_civicsi &raquo;</TD></TR><TR><TD CLASS="quote">i dont get it man??? isnt there something to do with swapping the wires,,, what you mean a hacksaw blade and chop rivets? and then flatblade// confused
why cant my b16 tps NOT be smashed :S</TD></TR></TABLE>
he meant because the TPS is held on with shear bolts/rivets there is no way to get it off unless you use a hacksaw or dremel tool to slot the heads. Then you can use a regular screw driver to get them off
Old Jun 1, 2004 | 01:34 PM
91_civicsi's Avatar
Default Re: 91 honda civic si TPS on a b16a1? (APEX CRX)
ok thanks man, now i gotcha, cant you use a ratchet???
Old Jun 1, 2004 | 01:40 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_civicsi &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks man, now i gotcha, cant you use a ratchet???</TD></TR></TABLE>
IF you were able to use a ratchet that would mean the TPS bolts have regular bolt heads (which they don't) thats the reasoning behind slotting the shear bolts and using the screw driver to get them off. Hope this all makes sense to you now.
Old Jun 1, 2004 | 01:44 PM
91_civicsi's Avatar
okay sweet, i'll try that,,, have any pics of twhat the botls look like?
Old Jun 1, 2004 | 02:14 PM
rioninja's Avatar
heres an idea, why dont you go outside and look at the tps?
Old Jun 1, 2004 | 02:44 PM
91_civicsi's Avatar
Default Re: 91 honda civic si TPS on a b16a1? (rioninja)
im at work man!
thats why i asked, im not lazy... lol
or i would
Old Jun 1, 2004 | 03:08 PM
rioninja's Avatar
This guy is selling a TPS.
https://honda-tech.com/zerothread?id=879072
Old Jun 1, 2004 | 03:18 PM
91_civicsi's Avatar
i have one on my 91 si,,, i just gotta take it off, u need the gasket too though eh?
malromes
Feb 28, 2011 03:08 PM
vegas hoe
Dec 11, 2007 08:43 PM
rexwreckjr
Honda Motorcycles
Jun 29, 2006 08:12 PM
greddy13
May 14, 2006 11:37 AM
