lsvtec?
Is it possible to run lsvtec without a knock sensor? Can you use obd1 gsr head, mate it with obd1 ls block with obd2 si harness and distributor? any help would be appreciated... thanks...
yes u don't need the knock sensor if u don't want it but I kept mine in case u know being it is Ls/Vtec
and well u can just stick a pin in the knock sensor clip to loop it and will think it is on
But that is if u go that route
and well I know the VAFC II has a knock sensro mode in it if u like it in case u rev to high !!!!
Chipped p28/p08 doesnt run knock. If intrested I have some in stock. polarbeartuning@yahoo.com for pricing and chips available.
i have an lsvtec in my teg...i put a knock sensor in mine just cause i wanted it done right...but i believe an apexi vafc will force the vtec to kickin without a knock sensor. I would recomend a knock sensor if your gonna be revvin the motor up..honda put it there for a reason
haven't checked the code yet but i think my car is in limp mode.... if i can't rev past 4100 rpm then thats limp mode right? correct me if i'm wrong but i'll have to check the code sometime this weekend. also would running unleaded 89 or 90 octane cause a rattling noise when driving? thanks guys..
Big Dick Bandit
Sep 28, 2003 04:54 PM
