help on mpfi conversion..........
Old Jun 1, 2004 | 09:55 AM
904drlx's Avatar
Default help on mpfi conversion..........
i just converted my 1990 lx civic to mpfi. found a 92 civic in the junk yard and bought all the stuff. i wired in the ecu, put the manifold and dist in, wired the injectors and resistor in. the car has strong spark, timing, and good fuel delivery. the car wont fire up! i ran a code scan on the car. it flashes a code 1 ande 41. (both 02 sensers) i did not get the 4 wire o2 off of the 92 civic, i still have the single wire o2 on the car. would that cause the car not to crank? please forgive me if this is a really stupid question.....i am brand new to the honda scene.
thanks in advance for any help
aaron
Old Jun 1, 2004 | 09:59 AM
HT Chaplain's Avatar
Loved
Default Re: help on mpfi conversion.......... (904drlx)
Use the o2 sensor for the ecu. If you changed out your ecu you will have to change out you o2 sensor 92=obd1 & 90 =obd0 did you do the obd conversion? because you cant use a obd1 ecu with a obd0 distributor & injectors they all have to be the same year or same obd. (inj, dist, o2,and ecu)
Old Jun 1, 2004 | 10:02 AM
904drlx's Avatar
Default Re: help on mpfi conversion.......... (LEGUTKI)
i am about to go and get the o2 sen and plug to wire up..... but would it really keep the car from starting???
Old Jun 1, 2004 | 10:04 AM
904drlx's Avatar
Default Re: help on mpfi conversion.......... (4drEF)
im actually using an accord resister and ninjectors with a sx adj regulator
Old Jun 1, 2004 | 10:06 AM
4drEF's Avatar
Keyboard Humorist
Hmm... check your spark plug wiring and timing belt timing?
Make sure all your grounds are in place.
Old Jun 1, 2004 | 10:09 AM
904drlx's Avatar
i did that all is well now im wondering about that o2 because that is the only codes i am getting. i am really puzzled tho, i have never seen a car not start because an o2 isnt hooked up. unless that is a honda thing!
Virgle DeBord
May 21, 2015 07:30 PM
gabrielsousa
Jun 11, 2014 06:44 PM
00jdmdc24sale
Mar 27, 2009 08:29 PM
93NTEGLS
Dec 5, 2007 10:01 AM
DocSean
Dec 9, 2004 08:21 PM
