check engine light popped on and then off.
Old Jun 1, 2004 | 07:19 AM
staticrex's Avatar
Default check engine light popped on and then off. updated
On the way to work today I got a Check engine light. It happened about 100ft from my job so I drove the rest of the way and then shut it down. I turned it off and started it back up and it went away. Do cel's usually do this? I will be checking the cel after work, all I need is a paperclip correct?
Will the code still be there even if the CEL light is not on?
Update at bottom
Modified by staticrex at 8:32 PM 6/1/2004
Modified by staticrex at 8:39 PM 6/1/2004
Old Jun 1, 2004 | 07:29 AM
delguiner's Avatar
Default Re: check engine light popped on and then off. (staticrex)
ya it will be stored inside the ecu.. check for codes there...
Old Jun 1, 2004 | 07:31 AM
staticrex's Avatar
Default Re: check engine light popped on and then off. (delguiner)
thanks
Old Jun 1, 2004 | 11:31 AM
staticrex's Avatar
Well I went out and got codes 22 and 36. So 22 is a vtec oil pressure switch. So would I just replace the switch or could it be unplugged or something. And the 36 I guess is a ghost code for the jdm P13 ecu. So anyway any help on the 22. Thanks
Please help.
Mike
Modified by staticrex at 8:50 PM 6/1/2004
Old Jun 1, 2004 | 11:51 AM
JDMSloLude's Avatar
22 is your VTEC Pressure Valve, and I think you might be reading the 36 incorrect.
RG
Old Jun 1, 2004 | 11:59 AM
staticrex's Avatar
Default Re: check engine light popped on and then off. (JDMSloLude)
I went out and checked all the plugs going to the vtec solenoid, and all seem to be on snug and clipped in, so maybe the switch is just defective. How much would one of these cost? Would it hurt the motor to drive it if it is defective, as long as I stay out of vtec?
any help is appreciated.
thanks
Mike
blackj30_a
Mar 30, 2016 11:20 AM
ph0shizzle
May 13, 2006 08:36 PM
jdm stan
Aug 14, 2005 12:59 PM
delsolgirl
15
Aug 13, 2005 01:34 PM
johnzm
Sep 13, 2002 02:39 PM
