what kind of power does this sound like?
Old May 31, 2004 | 11:40 PM
Tex Blackwell's Avatar
Default what kind of power does this sound like?
finally get a chance to run at the 1/4 track, rockingham
anyways,
it rains for bout 2 hours, then i finally get to run, heres my time:
13.2@111mph
falken azinis @ 24 pounds (didnt get a 2nd run in so i didnt get to run again w/ a lower psi)
plugs @ .030
lsd b16 tranny, b16 jdm obdo bottrom end, 00si top end. (stock)
act 6 puck disk w/ heavy duty pressure plate w/ 12.5 pound flywheel
dsm's w/ vafc
stock replaced headgasket, arp headstuds,
saab t3 turbo, tial wastegate 7.5 lbs, greddy type s bov
retarded ignition'
ssautochode manifold & downpipe
fmic
wet track.
i have already broken 3 passenger and 2 driver's side axles, (advance & autozone special warranty, GOTTA LOVE IT!!!)
then just yesterday, well 2 days now, on sunday, i take a friend for a ride, shifting into 2nd i break the neckof the passenger side axle that slides in the disk part of the wheel, straight up shattered, (200miles is how long it lasted)
a week before that, i broke the same passenger side axle , on the line, launching @ 5500 light turns green and it snapped so fast that i didnt even get to move an inch to at least get a reaction time. i get out and push it back while a guy yells "get a chevy".
then, this past friday night, i left a stock tt 93 rx7, bone stock, just keep it nicely tuned up and kept in perfect condition, only thing done to it is a vacum hose replacement and a replaced ground wire. got it on video, putting it online asap.
also, i have beaten:
two firebird ws6's 2000 body style
multiple mustang gt's and a mach 1
turbo evo8
time slip:
http://f2.pg.photos.yahoo.com/...a.jpg
anyways, what do you guys think that i may be pushing hp torque wise?
btw, 98 hatch
Old May 31, 2004 | 11:46 PM
Ramocheese's Avatar
Default Re: what kind of power does this sound like? (mp3albums2k2)
111mph traps on a honda (judging by weight, etc) typically sound like around 250ish to the wheels (give or take a little). The trap is good for 12's, but you just need a little more traction.
**EDIT** Didn't see that it was a hatch until after the post. A local turbo GSR with full interior local here made about 260 to the wheels and ran 110 traps.
Modified by Ramocheese at 2:17 AM 6/1/2004
Old Jun 1, 2004 | 12:14 AM
Mase's Avatar
Default Re: what kind of power does this sound like? (Ramocheese)
225 whp
170 ft/lbs
Old Jun 1, 2004 | 12:23 AM
leed's Avatar
Default Re: what kind of power does this sound like? (Mase)
Dam, great traps for a Saab T3. How much boost you up to?
Id guess 230-240 max on that turbo.
Old Jun 1, 2004 | 01:00 AM
SiR Kid's Avatar
New User
Default Re: what kind of power does this sound like? (leed)
I made 260hp at the wheels, my car weighs 2500 with me in it, and I trapped 112.7 last time at the track, with 0 traction in first, 50% in second, and it started to haul *** in 3rd.
Mine's a 90-91 LS tranny, non LSD on 195/50/15 Potenza street tires at 32 psi.
Old Jun 1, 2004 | 07:57 AM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">225 whp
170 ft/lbs</TD></TR></TABLE>
Ditto
Old Jun 9, 2004 | 05:26 PM
7.5 lbs
Old Jun 9, 2004 | 05:34 PM
mildly.interesting's Avatar
lol Tex, I thought that was you..I saw you cane the Rx-7 on CH.com...I can't believe you run a T3 and beat up on him like that..
Old Jun 9, 2004 | 06:49 PM
Bailhatch's Avatar
Default Re: (mildly interesting)
beware of the 50 trim T3!
Old Jun 10, 2004 | 05:40 AM
Default Re: (Bailhatch)
yea, i beat the 7, nothin wrong w/ the t3, thanks to the little advice a guy told me not far from my little shop,
Old Jun 12, 2004 | 08:33 AM
Default Re: (mp3albums2k2)
now, with this setup that i have rite now, i'm going to run on slicks, how do MT slicks 24.5X9X13 mounted on lenso's sound? I am not really sure on what size i should go on but the falken azenis are about 22' and i'm shifting into 5th goin down the 1/4, i figure maybe these might be a little overkill.
Old Jun 13, 2004 | 09:44 PM
Old Jun 13, 2004 | 10:03 PM
Stu's Avatar
Stu
New User
How do you have a stock Saab turbo and an external wastegate? did you just weld the flap shut?
Old Jun 14, 2004 | 10:40 AM
Default Re: (Stu)
take the wastegate off, then mount the t3 flange, and then use a manifold that uses an external wastegate.
twentyhurtz
Transmission & Drivetrain
Mar 22, 2009 10:28 AM
slotec
May 21, 2008 11:30 AM
psegs80
Oct 3, 2007 11:31 AM
2wheelhunter
66
Sep 13, 2007 10:12 PM
tjin83
Aug 30, 2006 07:43 PM
