I am starting to hate my car!! HELP??
Old May 31, 2004 | 11:09 PM
highpsief's Avatar
Default I am starting to hate my car!! HELP??
First off i'll tell you a little info on the car first.. 90' Dx hatch with a d16z6 mpfi swap, mitsu 14b, stock regulator, In line bosch secondary pump, Stock in- take pump, Vortech FMU,
The problem started today when the 2nd pump took a dump and it stopped wanting to rev over 1800 to 2000, So i pull it off thinking thats the problem( maybe the pump broke and was not alowing fuel flow??) just a thought? We'll the problem is still there?? SO i go through and mess with everything with no luck? I pulled the return line off and put it in a can to see if there was any signs of possible fuel flow issue's and no problems thier... But everytime i hold it to the floor, and it just stumbles around 1800 it leans out really bad like 15:1, I let off a little and richens back up and will run fine for like 2 seconds?? then start it all over agian?? Also, Just idling it is really rich?? I just dont get it?? I pulled the CEL and it cam up with a 9,10, 14.
the code 14 made me think it was something with map sensor, But i tried 2 others?? the only other thing i can think of is a ignition problem?? BTW, It has a modded b16 obd-0 distributer...
Any help woulg be appriciated..
Old Jun 1, 2004 | 12:15 AM
diulay_pkjai's Avatar
Did you use a check valve? Maybe the ecu is reading boost and going into limp mode.
Old Jun 1, 2004 | 12:38 AM
highpsief's Avatar
Default Re: (diulay_pkjai)
I checked them, It does it without even boosting..
Old Jun 1, 2004 | 04:03 PM
highpsief's Avatar
Default Re: (highpsief)
ttt
cardudelude
11
Jul 28, 2010 12:22 PM
Perkul8r
Aug 4, 2009 10:57 AM
cuseikan
Aug 14, 2008 06:24 PM
urbansi
17
Feb 21, 2007 01:25 AM
Boognish
Jul 24, 2005 06:03 PM
