1990 Honda Civic Si Engine Swap
Old May 31, 2004 | 10:59 PM
Kagemusha's Avatar
Default 1990 Honda Civic Si Engine Swap
I need help deciding what kinda engine swap to do. Here's all the info I've gathered on my car:
VIN: 2HGED7369LH505801
Year: 1990
Make: HONDA
Model: CIVIC Si
Country: USA
Generation: 4G
Engine Type: 1.6L, 4 Cylinder, 108hp, Gas, Fuel Injection
Engine: D16A6
Displacement: 1590
Horsepower: 108@6000
Torque: 100@5000
Compression: 9.1:1
Valve train: SOHC 1.6L 16-Valve SOHC
Curb weight: 2127
Fuel Type: Gasoline, Fuel Injection
Body Type: 3 door hatchback, FWD
Chassis: ED736
Transmission: 5 Speed Manual
I was looking into doing a Mini-Me Swap to a D16Z6 head /w the original D16A6 bottom-end. I was also looking at a B16A6 or B16A swap. I really don't know the difference b/w a B16A and a B16A6. Any help would be useful along with any links to guides or ANYTHING!
Old May 31, 2004 | 11:00 PM
Kagemusha's Avatar
Default Air Intake & Filter
There is also a K&N Air Intake & Filter installed on the car, but I guess if the engine fits so should the intake, eh? it just bends to the front-left w/ a cone-like mushroom filter.
Old May 31, 2004 | 11:44 PM
Redline130's Avatar
Default Re: Air Intake & Filter (Kagemusha)
First of all, there is no B16A6. The main deciding factor is going to be your budget. If you are tight on funds, then doing a mini-me or swapping in the entire D16Z6 is one of the options you could take. Another would be to leave your existing motor in and piece together a turbo kit. If you have sufficient funds, then by all means, swap in a B-series motor. Use the search function on this site, there is tons of info on this topic.
Old Jun 1, 2004 | 10:09 AM
Kagemusha's Avatar
Default engine code mistake
what b-series motor would fit w/ major modifications such as modified mounts, removal of AC, etc. i meant a B16A1... oops. whats the difference b/w a b16a1, a2, or a3? is a b18 smaller/more compatible w/ my car?
Old Jun 1, 2004 | 10:41 AM
mrquimbie's Avatar
Default Re: engine code mistake (Kagemusha)
If you have the time to read check out this site. Should have all the info you are looking for. http://tech.hybridgarage.com/
Old Jun 1, 2004 | 10:46 AM
crx_88_si's Avatar
if you decide to do a mini me swap use the d16y8 head so your stock d16a6 distributor will bolt right on perfectly.
Old Jun 1, 2004 | 07:22 PM
Kagemusha's Avatar
Default car problems are the begining
well it seems my cousin that did his own engine swap to his honda civic, i think it was the vtec prelude jspec engine or something, has come across a d16z6 head i think it is... for the mini-me swap. im still looking into the d16y8 head and what the difference is, etc. my cousin is gunna sell me the head for 125$ and i need to buy the vtec comp. and he'll do the work.
but as for other problems... INSURANCE! im 19yrs old male! expensive + no job = screwed. imma spend most my time trying to get money for the comp. and the head from/for my cousin. anyone know any prices on the required computer? also i need to get my license this week! LoL... and a job!
ps. thanx for all the help
Old Jun 1, 2004 | 11:11 PM
mr. carpenter's Avatar
Default Re: car problems are the begining (Kagemusha)
to run the vtec you'll need to swap to obdo1 or get a hondata or zdyne ecu. i used the zdyne and it cost me about 330$.
Old Jun 2, 2004 | 06:44 AM
EJ2-Fluffy's Avatar
GEt a job before you work on the engine man! You cant pimp the girls and ride w/o the blang blang man!
Old Jun 2, 2004 | 07:13 PM
Kagemusha's Avatar
Default obdo1?
whats an 'obdo1'? the head is only 125 bucks and the ECU is 330bucks?!?!
any cheap alternatives? and do i need something to convert the voltage?
Old Mar 4, 2013 | 02:25 PM
palvarez's Avatar
Default Re: 1990 Honda Civic Si Engine Swap
I need reware honda civic si 1990 and swap engine 1996 vtec how i do that the engine is ready in de car:
Old Mar 4, 2013 | 05:51 PM
BYOB916's Avatar
If your gonna swap it then swAp it to a b series, swapping your single for another single isn't worth the time/money.
Old Mar 4, 2013 | 06:10 PM
m_shake's Avatar
Holy Jesus ******* Christ 9 year old thread bump?!? Also it's "rewire" not reware and "the car" not de car. As far as a actual answer, convert to obd1 and use a p28. Search goddamnit
Old Mar 4, 2013 | 06:52 PM
M-benz's Avatar
Lol
La Voz
Honda Civic (2006 - 2015)
Nov 1, 2014 11:21 PM
grover1978
12
Mar 6, 2012 08:29 AM
Viper456
Mar 23, 2010 02:31 PM
rz514
Jun 21, 2006 02:25 PM
crazyywhitemike
Aug 16, 2004 01:38 PM
