The kit is almost together. Build bottom end or not?
Old May 31, 2004 | 09:43 PM
pushinlsteg's Avatar
Default The kit is almost together. Build bottom end or not?
I'm gonna be running B18B with t3/t4 turbonetics, 54 trim, .63 A/R. 450 DSMs, spearco IC, SSQV BOV, tial 38mm WG, 7 psi spring. drag manifold, etc etc, stock block, PnP head(being built right now) with 140,000 miles on it on Uberdata. I don't burn any oil. I don't have any clouds coming out the back of my car. On the compression test I got 175 across the board except for #3 I had 162, but I have some valve issues there I know for sure so all should be cured with the new PnP head.
I only want to boost 7 psi, dyno tuned. Until I find another block I can build up to boost more. WILL my motor be safe on 7 psi with the mileage it has? People are saying I have to get new bearings....and I'll have to get some forged pistons and all this jazz. SO if anyone knows how my motor will handle 7 psi let me know. My turbo is relatively big but not really, should pull hard as hell after the lag. Let me know what you all think, thanks in advance (94b18b1teg)
Old May 31, 2004 | 09:57 PM
MachAF's Avatar
Default Re: The kit is almost together. Build bottom end or not? (pushinlsteg)
140k miles is a lot.
Turbo it... when something breaks, then its time to build the block.
Old Jun 1, 2004 | 02:47 AM
bump it up
Old Jun 2, 2004 | 06:54 AM
bump for some more opinions.
Old Jun 2, 2004 | 07:01 AM
DaX's Avatar
DaX
Loved
Community Favorite
I'm in a similar boat, and I'm just going to boost it until something breaks. I'm expecting the headgasket to be the first thing to go.
Old Jun 2, 2004 | 10:45 AM
Default Re: (DaX)
well I'm putting a fresh head on before the turbo, with a brand new felpro headgasket, so that should be fine. the ONLY thing I'm worried about is my rod bolts stretching and letting go, or the bearings.
Old Jun 2, 2004 | 11:10 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (pushinlsteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushinlsteg &raquo;</TD></TR><TR><TD CLASS="quote">well I'm putting a fresh head on before the turbo, with a brand new felpro headgasket, so that should be fine. the ONLY thing I'm worried about is my rod bolts stretching and letting go, or the bearings. </TD></TR></TABLE>
I've heard horror stories...
Old Jun 3, 2004 | 05:26 PM
bump it up some more
BluSiBoy
Jun 16, 2005 05:20 AM
LilCivic04
May 31, 2005 09:12 AM
LilCivic04
Feb 1, 2005 06:04 PM
94B18B1Teg
Apr 26, 2004 07:25 PM
BOOSTIN1
Jan 11, 2004 03:31 PM
