ABS light
Old May 31, 2004 | 08:51 PM
Old_Honda's Avatar
Default ABS light
In my '92 GSR, while cruising at freeway speed (70+), my abs warning light comes on and stays on until I turn the car off and back on, but when I turn the car back on it goes away until I take the freeway again. I checked for codes from that led on the abs control unit next to the rear passenger seat but found none. Any ideas would be much appreciated, Thanks!
Old May 31, 2004 | 09:10 PM
civic_hatchback's Avatar
Default Re: ABS light (OldGSR)
Maybe its when you use your brakes for a while?
Old May 31, 2004 | 09:25 PM
Old_Honda's Avatar
Default Re: ABS light (civic_hatchback)
no, cruising=not much stopping
Old May 31, 2004 | 09:29 PM
Oh my bad. Sorry, hope someone here helps you. Good luck.
Old Jun 5, 2004 | 05:48 PM
SOHC Gord's Avatar
check your brake fluid sometimes the light will come on just bc it is low
Old Jun 5, 2004 | 10:57 PM
4crx4me's Avatar
You can take the cover off and read the code on the ABS ECU.
I don't know what your problem could be but, the reason the light goes off when you shut off the car, but then comes on again is because the system resets it self. But the problem is chronic not acute, so the light comes back on when the cicumatances that caused it to go in the first place, are the same.
HTH
sixtodc2
Oct 4, 2007 04:15 AM
redINTEGRAdriver
Jan 31, 2005 12:01 PM
f22suzuka
Apr 21, 2004 10:15 AM
tintin11
Jan 27, 2004 01:30 PM
oioioi
Oct 11, 2002 02:47 PM
