Bay Area: Where can I get custom piping done???
Just looking for turbo to intercooler and intercooler to throttle body piping.
Where do you guys recommend???
More specifially, i'm looking for 2.5" from turbo to intercooler and 3.0" from intercooler to throttle body.
TIA
TIA
i can make you some custom iC pipes, however arent those sizes a bit big? or are you runnin this on a BMW? i usually do mild steel tig welded stuff, just got into welding aluminum but im not a pro at it yet. if its a honda, i can make you IC pipes for 280$ in the size oua sk for. if its somethin else i need to know.
Yes, this is for a BMW 325ic.
I need someone who can measure and know what to make/bend once I get there.
Am I asking too much?
dyno labs in san ramon can help you out
http://www.honda-central.com/r...age=1
hoover is the guy that does alot of the fab stuff. I think they have alot of different metal and piping in stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dinan330ic »</TD></TR><TR><TD CLASS="quote">Yes, this is for a BMW 325ic.
Am I asking too much?</TD></TR></TABLE>
youll get u bends which are cut to fit and welded up together mandrel. mind you
however its gonna be hard for you to find anywhere to make you any 1 piece charge pipes like custom bent. a mandrel bender is $$$$$$$$$$$$$$$$$$$$
BTW i do think 3 inch from IC to TB is too big.. 2.5 all around is sufficient for your HP goals unless you plan on anything over 900
eg:R
Nov 30, 2005 12:36 AM
