compression quistion
Old May 31, 2004 | 07:04 PM
allmtrdc4's Avatar
Default compression quistion
does anybody know if you can run type r pistons and type r rods and a ls crank in a b18b for building an all motor ls or will i have to run a ls rod i want my cr as high as i can get it with out putting a valve through a piston
Old May 31, 2004 | 07:25 PM
Eviloliv3's Avatar
Default Re: compression quistion (allmtrdc4)
if you have a LS Crank, you need LS rods. you need a matching crank and rods to make it so you dont come up short, or shoot the piston into the head. unless you get a deck plate
Old Jun 3, 2004 | 04:05 PM
Publius1775's Avatar
you can put the itr pistons on ls rods with a little work (have I think 1mm shaved off of each side at the top). the same goes for ctr pistons (bigger dome, higher CR). itr rods on an ls crank cannot be done though, because the big end diameters are different. conversely, you could put in a gsr or itr crank and keep the itr rods, since all of those pieces are stronger that their ls counterparts (gsr crank are pretty cheap used).
turbodcxbro
25
Jan 7, 2010 07:30 AM
dc4teg95
Jun 12, 2007 11:21 AM
94si94cx
Jun 21, 2004 10:49 AM
slodel
Jun 18, 2004 12:14 AM
