jumping tach?
Old May 31, 2004 | 06:33 PM
importboi22's Avatar
Default jumping tach?
i just installed a gsr cluster into my hatch and the tach jumps to 0 after i hit about 5800- 6k rpms, what could be the cause? i pulled my distro and made sure all my connections were tight, anything else that could be causing this? i wanted the gsr tach cuz im putting in skunk2 stage 2's on a b16 and i wanted something that could read to 9k but now the tach is totally worthless
Old May 31, 2004 | 06:55 PM
SiRex91's Avatar
Default Re: jumping tach? (importboi22)
Check all your grounds
Old May 31, 2004 | 06:58 PM
mr. carpenter's Avatar
Default Re: jumping tach? (SiRex91)
i know a bad distributor will cause a tach to jump. did you solder all the wiring you did on the cluster?
Old May 31, 2004 | 07:14 PM
fourthgenhatchB17's Avatar
Default Re: jumping tach? (mr. carpenter)
Possible sign of a bad ignitor.
Old May 31, 2004 | 07:32 PM
but see the weird part is, it used to jump before so i spliced the tach to the ECU and it worked fine, now that i ran the gsr cluster its jumping =\ yes i solder all the connections also
Old May 31, 2004 | 07:33 PM
just added a ground distro to the battery still jumps
Old May 31, 2004 | 07:40 PM
stupid ignitor, wonder if a used one will work, oh well worth a shot! oh ya all the connections are tight on the ignitor currently
Old May 31, 2004 | 09:54 PM
noooo ignit0R
quicksilver1689
Oct 23, 2008 11:14 PM
littlegreenb18
Jun 2, 2006 03:04 AM
AFAccord
Jan 3, 2006 05:30 AM
Chase
33
Sep 29, 2005 07:53 PM
frostee trooper
Feb 6, 2005 10:58 PM
