...only weird clicking noise
Old May 31, 2004 | 06:32 PM
riceburners1's Avatar
Default ...only weird clicking noise
there is a 'clicking'/'clanking' noise....very subtle...only happens sometimes...and it's in the 'timing belt' area of my car in the engine bay....ill have to take a look when it's light out....but does anone have any idea what it could be??
Old May 31, 2004 | 06:33 PM
Default Re: ...only weird clicking noise (riceburners1)
wtf.....i must have been half asleep when i wrote the topic title....lol sorry
Old May 31, 2004 | 07:08 PM
DXDOHCVTEC's Avatar
Does it sound like a pully/bering of maybe somthing fell down there or it may be a water pump wearing noise? too many possible things it could be.
Old May 31, 2004 | 07:13 PM
i have no clue...ill look tomorow...and let you know....thanks
Old May 31, 2004 | 09:00 PM
atomikpunx's Avatar
does the tach jump also at all?
i know i had clicking turned out to be a loose starter.
Old May 31, 2004 | 10:00 PM
B1TEM3's Avatar
Default Re: (atomikpunx)
I had that noise near timing belt too,
i traced it to the water pump, water pump bearing worn out, so the gear wobble. timing belt was hitting on the cover. when the wobble got worse, I stop driving the car.
Old Jun 1, 2004 | 07:58 AM
DXDOHCVTEC's Avatar
If it is the water pump pully about to break you should also stop driving it before it does because then you will have worse problems for sure.
Old Jun 1, 2004 | 06:02 PM
im pretty sure it's coming from under the timing belt cover....whats under that....just the timing belt and camgear????...........and how do i get the cover off so i can asses the problem
Old Jun 1, 2004 | 08:33 PM
bumpity bump bump
Old Jun 1, 2004 | 11:05 PM
mr. carpenter's Avatar
Default Re: (riceburners1)
there are some 10 mm bolts on the side. there is a top and bottom part to it. to get the top off you need to loosen the valve cover. to get the bottom off you need to remove the crank pulley bolt. good luck.
Old Jun 2, 2004 | 07:18 AM
-slow ej-'s Avatar
Default Re: (mr. carpenter)
it might also be your alternator because i had the same problem and i replaced my timing belt and alternator since it did need a new one and then after that it stop making that noise
Old Jun 2, 2004 | 10:26 AM
where is the alternator located????
thanks again guys!!
Old Jun 2, 2004 | 10:53 AM
90SICRX's Avatar
Do you have a/c? My a bearing on the pully on the a/c on my car went bad so it sounded like the car was going to blow up. I couldn't figure out what it was, it sounded like it was coming from under the timing belt cover. Alittle trial and error and when i took off the belt for the a/c the noise quit! So yeah check that out.
Old Jun 2, 2004 | 10:57 AM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: (90SICRX)
Intermitted valve tap? My B16 has this. just make surre it is not coming from the valve cover.
Ge-money
Sep 6, 2006 02:55 PM
dornon13
Oct 3, 2005 09:45 AM
HondaFanatic708
Mar 31, 2005 06:08 PM
-slow ej-
Feb 26, 2004 09:38 AM
Drew96EJ
Oct 30, 2003 01:48 PM
