Whats a good header???
Just wondering what u guys would recomend for a header. Do i stick to DC sports or can i go with some thing cheaper like ractive or airmass??? what about Chikara from hedman??? Hedmans been making headers since before i was born. Are they any good?? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allicedout »</TD></TR><TR><TD CLASS="quote">Just wondering what u guys would recomend for a header. Do i stick to DC sports or can i go with some thing cheaper like ractive or airmass??? what about Chikara from hedman??? Hedmans been making headers since before i was born. Are they any good?? thanks</TD></TR></TABLE>
my friend put a chikara header on his car will he was waiting on his swap its ok better than stock matters what your plans are for the car and what engine? If you want to make alot of power go with a more expensive nicer header..if you want a little more power why not go with cheaper header or even ebay header.
DEF
DEF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erebunicrx »</TD></TR><TR><TD CLASS="quote">if its a b series and want a cheaper one go with a jdm type r. if you have more money go with a toda or jun.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRex91 »</TD></TR><TR><TD CLASS="quote">Bisimoto header
Bisimoto is the way to go, albeit it's a bit more then some of the other headers.
There are so many headers out there that it can be hard to chose. Available headers range from $150 Pacesetter headers to $1300 Hytech headers. Also keep in mind that some headers work better for some applications while another brand might be better for a different application. As for DC, there are better headers out there. But you will pay. DC headers are both relatively inexpensive and at least decent. I would certainly not get something that is totally cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nontent »</TD></TR><TR><TD CLASS="quote">
Bisimoto is the way to go, albeit it's a bit more then some of the other headers. </TD></TR></TABLE>
This brings up yet another point. Some headers (like this particular one) require that you give up your A/C. If you live in a hot climate and this does not appeal to you, you might want to consider another header. Generally speaking, a more 'mainstream' header like DC will not require that you give up your A/C. But others might. Be sure to ask about this before purchasing.
Bisimoto is the way to go, albeit it's a bit more then some of the other headers. </TD></TR></TABLE>This brings up yet another point. Some headers (like this particular one) require that you give up your A/C. If you live in a hot climate and this does not appeal to you, you might want to consider another header. Generally speaking, a more 'mainstream' header like DC will not require that you give up your A/C. But others might. Be sure to ask about this before purchasing.
POE
20
Jan 30, 2004 11:15 AM
