clutch trying to pull the car when fully depressed
Old May 31, 2004 | 02:07 PM
vtecmissle's Avatar
Default clutch trying to pull the car when fully depressed
Heres the problem if i rev up the car with the pedal to the floor at the higher rpms the car tries to pull a little. I car feel the engine rock hard. It doesnt move the car but if i didnt have the brake on it would. I also occasionaly grind when i shouldnt. Ive had a similar problem before i wonder if my hydraulic system is starting to fail.
Old May 31, 2004 | 02:30 PM
milton's Avatar
Default Re: clutch trying to pull the car when fully depressed (vtecmissle)
maybe its the clutch master cylinder?
Old May 31, 2004 | 03:34 PM
Thrillhouse's Avatar
Default Re: clutch trying to pull the car when fully depressed (milton)
cable or hydro, either way could be out of adjustment, also check your motor mounts, if not could be something more serious like PP out of alignment.
Old May 31, 2004 | 03:49 PM
IN VTEC's Avatar
Has the hydraulic system ever lost pressure to the point of having to pump the pedal to get it to come back up?
The clutch hub and/or pressure plate also might be damaged.
Old Jun 10, 2004 | 03:10 PM
vtecmissle's Avatar
Default Re: clutch trying to pull the car when fully depressed (IN VTEC)
i believe so but it was fine after that for a while.
Jcd5
Transmission & Drivetrain
Jul 24, 2014 11:40 AM
Rickcrx
Mar 11, 2010 04:30 PM
sihonda
Nov 24, 2006 05:43 PM
RTW DC2R
Jun 23, 2006 07:42 AM
notstock93
Jan 14, 2005 03:24 PM
