oil pan plug
Old May 31, 2004 | 01:30 PM
prettyQuik's Avatar
Default oil pan plug
I just bought another crx and when i was changing the oil, some how the oil pan plug bolt got striped. Its not leaking alot, but just enough to put stains in the drive way. Is there any way to temporarliy fix that, or rethread it?
Old May 31, 2004 | 01:34 PM
tilt's Avatar
Default Re: oil pan plug (rexboyb18)
yeah you can use a tap and die kit. it might be hard to find one that is big as the drain bolt hole though.
you can prob either rethread the current one or weld it shut and tap a new hole and thread it. or you can get a new oil pan. gool duck.
Old May 31, 2004 | 02:33 PM
mr. carpenter's Avatar
Default Re: oil pan plug (tilt)
get an oil pan from a junk yard.
Old May 31, 2004 | 02:38 PM
viper_2_4's Avatar
what I did when I went to change my tranny oil and found the bolt stripped was I drilled a small hole in the bolt head and used a pin looking thing (can't remember the name) and wacked it with a hammer (after soaking it with pennatrating oil), it was enough to knock it loose so that I could take the rest off with vice-grips....but that might not work quite as well with a oil pan, since it is softer, so you may want to just replace the oil pan.....
Old May 31, 2004 | 04:26 PM
shaddr3's Avatar
Default Re: (civiccxr)
replace the whole oil pan, its cheap too
Old May 31, 2004 | 05:49 PM
RCautoworks's Avatar
Default Re: (shaddr3)
I think autozone actually sells a coked plug, but I would just go fine a used oil pan.
Old Jun 9, 2004 | 04:48 PM
EVOCELICA's Avatar
New User
not sure if it will work for you but it worked on my b series use a acura lengend drain bolt it is longer and catches the threads that the civic bolt doesn't
Old Jun 11, 2004 | 01:45 PM
prettyQuik's Avatar
Default Re: oil pan plug (EVOCELICA)
worked! thanks
Old Jun 11, 2004 | 02:01 PM
EVOCELICA's Avatar
New User
no problem, it's a good little piece of info to have worked a bunch of times for myself
Old Jun 15, 2004 | 07:55 AM
Akiraboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOCELICA &raquo;</TD></TR><TR><TD CLASS="quote">not sure if it will work for you but it worked on my b series use a acura lengend drain bolt it is longer and catches the threads that the civic bolt doesn't </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOCELICA &raquo;</TD></TR><TR><TD CLASS="quote">no problem, it's a good little piece of info to have worked a bunch of times for myself</TD></TR></TABLE>
btw, d series bolt thread pattern is M14x1.5, I found out the hard way
I have the same prob & I can't pull my oilpan as easily, need to pull the transfer case (that really sux)....I have a tap & I'm gonna try to rechase the threads & see if that works besides I was lookin for longer bolt incase the first 1-2 threads don't catch.
thats a good one, thx
(i'll put the gun down now & you can have the thread back)
Old Jun 15, 2004 | 07:59 AM
EVOCELICA's Avatar
New User
Default Re: oil pan plug (HONDACIVICWAGON.COM)
no problem
userjh5174
Aug 20, 2012 02:27 AM
jdmda_1.7a
Feb 15, 2011 07:35 AM
CRXified
18
Oct 31, 2006 04:58 PM
equinox
Jul 7, 2006 12:55 PM
MechEng
Oct 21, 2005 12:14 PM
