93 LS Project
Old May 31, 2004 | 11:14 AM
Nevets's Avatar
Default 93 LS Project
I have a 93 LS with 185,000 miles. IS it worth the build up or should i just save up for a swap?
Old May 31, 2004 | 11:30 AM
Colin's Avatar
Default Re: 93 LS Project (760DA9)
depends on what you want to build..... there is no yes or no answer to your question. Building up that motor may be more or less expensive than a swap (since it depends on what mods you do, and which swap you're comparing it to), and in the same way.... there is no yes/no answer to which motor will have more power or be more suited to what YOU want.
Old May 31, 2004 | 11:45 AM
Nevets's Avatar
Default Re: 93 LS Project (91IntegGS)
well im really considering LS/vtec if i keep the motor. But then down the road i might want to turbo it.
Old May 31, 2004 | 11:47 AM
..::91TEG-G2::..'s Avatar
keep the ls block, built it up... cuz with that kinda mileage, your due for an overhaul anyways.. then slap the turbo on...
always remember, lower compression equals good for turbo
Old May 31, 2004 | 12:28 PM
Nevets's Avatar
Default Re: 93 LS Project (..::91TEG-G2::..)
Thanks for the replies.
Anymore opinions would be greatly appreciated.
pooRmansss
Feb 22, 2009 09:39 AM
noodlez1390
Jul 3, 2008 12:43 PM
Mr. Em1
15
Jan 3, 2006 09:52 AM
Wrath of VTEC
Dec 13, 2004 03:27 PM
Inaniac
10
Jul 11, 2001 07:43 AM
