'91 teg LS, NJ, 2.5k
'91 LS 197k 5spd, dark grey int, metallic maroon ext, runs good, reliable
Exedy Organic clutch( like stock ) and plate, bushing, throwout bearing, flywheel resurfaced
Eibach Pro Springs
KYB AXG adjustables on front, GR2 on back
Ingall camber kit on front, extended bolts n washers on rear.
Perfect alignment- camber, toe- rides straight and wears evenly.
Polyuro rear trailing arm bushings, shifter bushings
Primax 618s 15"
Last summer new Dunlop Sport A2s
passed NJ inspection in october
MUCH replaced... all in last 30k miles on car
all brake calipers except front pass side, brake master cylinder, brake fluid changed, all front control arm bushings, front and side motor mount, front brake rotors, brake pads, all hoses, timing belt, thermostat, water pump, o2 sensor, fuel relay unit, distrib cap n rotor, platinum plugs, accel spark plug wires, alternator..
the bad and ugly.
A/C needs a recharge. normal door dings around car from the obvious. few dings on hood. in rear by exhaust the lower part of the bumper has some chipped paint. AND, normal left wear deal on driver's side seat.
pics avail on req
2.5k OBO
located in central/east new jersey
Eibach Pro Springs
Primax 618s 15"
the bad and ugly.
pics avail on req
2.5k OBO
