type r head on b16
Old Nov 10, 2001 | 12:18 PM
AfEn808's Avatar
New User
Default type r head on b16
anybody ever put a type r head on a first gen b16 i was thinking about doing this but i want to know if it will work or not.
Old Nov 10, 2001 | 02:55 PM
xtrafastcivic's Avatar
Default Re: type r head on b16 (AfEn808)
if what would work??? a type r head is a b16a head just a mild port and polish job straight from the factory.
Old Nov 10, 2001 | 04:56 PM
AfEn808's Avatar
New User
Default Re: type r head on b16 (XtraFastCRX)
i know it would bolt up but do i need a different ecu or what like do i have to change anything.
Old Nov 10, 2001 | 08:30 PM
CRX_VTEC's Avatar
Like he said...the type R head is EXACTLY the same as the b16. Only difference is the slight P&P, valvetrain, and cams. other then that a R head is basically a B16 head with mild port and polish...
Old Nov 11, 2001 | 01:00 PM
crxshark's Avatar
New User
Default Re: type r head on b16 (CRX_VTEC)
if you wanted to put the cams tand the valvetrain in the b16 engine, you dont need a new ecu, but it would make a lot more power if you had the ecu chipped. putting a type-r head on a b16 bolts right on, but as they said they're nearly identical, so dont spend the money on the whole head.
Old Nov 13, 2001 | 05:33 AM
evo's Avatar
evo
New User
Default Re: type r head on b16 (crxshark)
Is it useful to skim off 0.15-0.25 mm off the head B16A1, coz the engine has done 130K miles, d't want put too much stress to it.
How much compression ration would raise if skim off 0.15, please help.
wwcrxww
Mar 26, 2014 04:13 PM
SmoKez
May 10, 2012 08:56 AM
94whitegsi
Oct 4, 2006 07:17 PM
ramtyper19
Oct 5, 2005 08:09 PM
Rice Is Best
11
Feb 15, 2005 05:47 PM
