disconnect door buzzer?
Old May 30, 2004 | 09:42 PM
dingusjt's Avatar
Default disconnect door buzzer?
I could of sworn that 88-91 civics didn't come with a beeping door buzzer or whatever..i just bought this car and it's malfunctioning so i was wondering where to disconnect it? it would be the passenger door.
Old May 30, 2004 | 10:43 PM
DJ_SaNdOz's Avatar
Default Re: disconnect door buzzer? (dingusjt)
is it a door buzzer, or a seatbelt buzzer that you're having issues w/?
Old May 31, 2004 | 02:33 AM
Riceburner247's Avatar
Default Re: disconnect door buzzer? (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">is it a door buzzer, or a seatbelt buzzer that you're having issues w/?</TD></TR></TABLE>
ditto.
Old May 31, 2004 | 06:38 AM
dingusjt's Avatar
Default Re: disconnect door buzzer? (riceburner247)
honestly couldn't tell you...i assumed that we didn't have door buzzers being that people to the door buzzer mod so it must be seatbelt...
it goes off when i hit bumps and stuff..yeah must be seat bealt because i know the door one is like(if this makes sense)
dah dah dah dah......dah dah dah dah....dah dah dah dah
this one.
beep.......beep......beep.......beep
Old May 31, 2004 | 08:26 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt &raquo;</TD></TR><TR><TD CLASS="quote">dah dah dah dah......dah dah dah dah....dah dah dah dah</TD></TR></TABLE>
That's the door.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">beep.......beep......beep.......beep </TD></TR></TABLE>
That's the seat belt.
There is a problem in your seat belt system somewhere. I would have it checked out if I were you.
You may or may not be able to stop it from beeping in the meanwhile by unplugging the seat belt connector under your seat. However, if the problem is related to the door, it probably won't help. My '91 CRX seat belt seat connector is unplugged, so the warning doesn't go off if the belt is left unlatched, but if the door isn't latched tightly shut all the way then it will still beep.
What car do you have again?
Old May 31, 2004 | 08:27 AM
ICeDoUt's Avatar
hahah, yea that 4 beeping one is for the door, that other beeping one is the seat, u can disonnect it right under the seat. There is a plug u can disconnect and thats it, really easy, but it might be hard gettin to unless u unbolt your seat. Or unless u got skinny arms
Old May 31, 2004 | 09:51 AM
dingusjt's Avatar
Default Re: disconnect door buzzer? (ICeDoUt)
definitely don't have skinny arms....is it right by the seatbelt buckle, bottom snap-in-thing? (technical jargon)
Old May 31, 2004 | 10:33 AM
ICeDoUt's Avatar
there is a wire harness about 2-3 wires that comes out from under the senter of the seat, just follow that untill it comes to a part where u can dissconnect it, or u can just get some wire cutters, the easy way out.
Old May 31, 2004 | 11:39 AM
91civicEX's Avatar
for the door beeper
the beeper itself is by the ignition switch. unbolt the covers and youll see it. its a little black switch bolted to the metal housing of the ignition switch. cut the wires and your done. no more beeping but the "door" light still functions so you know when its open
Old Jun 2, 2004 | 01:42 PM
4DRmafia's Avatar
Default Re: disconnect door buzzer? (91civicLX)
u mean the little black block on the ignition? is it on the back of it or in front of it...i have the same plms
Old Jun 2, 2004 | 02:46 PM
4DRmafia's Avatar
i found my issue, it going from the seat belt and is there any way i can cut off the sound from the fuse box speaker or is there an wire going from there?
Old Jun 2, 2004 | 04:08 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">for the door beeper
the beeper itself is by the ignition switch. unbolt the covers and youll see it. its a little black switch bolted to the metal housing of the ignition switch. cut the wires and your done. no more beeping but the "door" light still functions so you know when its open</TD></TR></TABLE>
this will solve your beeping problems. instead of cutting anything tho, just open the key-in sensor and put a piece of electrical tape between the contacts.
its not coming from the fuse box.
Old Jun 2, 2004 | 05:44 PM
4DRmafia's Avatar
no my plm is with the seat belt beeper
Old Jun 2, 2004 | 06:23 PM
91civicEX's Avatar
Default Re: disconnect door buzzer? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
its not coming from the fuse box.</TD></TR></TABLE>
that works too
Old Jun 2, 2004 | 06:33 PM
4DRmafia's Avatar
*** monkeys lol, i still dont get what part on the ingition lol, theres like pretty much wires going through in ingition
Old Jun 2, 2004 | 09:42 PM
sit220's Avatar
Default Re: (civicsidude91)
those beeps come from those two seat belt signs at the mirror
so to stop the beeping take the mirror off u can unplug the system but if u want to keep the little libhts u can dig a little more and take the litlle speaker off
Old Jun 2, 2004 | 09:43 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 &raquo;</TD></TR><TR><TD CLASS="quote">no my plm is with the seat belt beeper</TD></TR></TABLE>
oh, sorry, sit220 has the right answer. the buzzer is up there, not in the dash.
Old Jun 3, 2004 | 08:18 AM
4DRmafia's Avatar
u mean it in the door panels ?
Old Jun 3, 2004 | 09:22 PM
sit220's Avatar
no the roof
Old Jun 3, 2004 | 11:38 PM
dingusjt's Avatar
black box by ignition..cut wires...nothing
plug under seat...disconnected...nothing
indicator light area on roof....unplugged...success!!!
Old Jun 4, 2004 | 04:59 PM
sd.coupe's Avatar
Default Re: (dingusjt)
how do u unplug the indicator light on the roof? im having the same problem.
Old Jun 4, 2004 | 05:02 PM
Tyson's Avatar
Default Re: (sdhatch)
pry off the cover, unscrew the 3 phillips head screws. pretty simple.
Old Jun 4, 2004 | 05:35 PM
sd.coupe's Avatar
Default Re: (Tyson)
k cool
Old Jun 4, 2004 | 05:48 PM
sd.coupe's Avatar
also my door light comes on.... but the door is for sure shut. wtf is up with this.. ? lol
Old Jun 4, 2004 | 06:16 PM
4DRmafia's Avatar
huh taking the whatever up the roof helps stop the seat belt beeping ?
