What welder to buy?
Old May 30, 2004 | 07:51 PM
nitekidsef9's Avatar
Default What welder to buy?
sorry if this is a tired subject but im really hung up on this one. I want to start fabin just learn how to and whatnot. Which welder on this link is good for fabing exh/FMIC pipes and manifold ect...
http://www.canadiantire.ca/***...80477
Cheers
Greg
Old May 30, 2004 | 08:41 PM
PrecisionH23a's Avatar
Default Re: What welder to buy? (nitekidsef9)
FMIC will require a welder that can do aluminim tig welding. Those machines can run an easy $1500 bucks.
MIG welding is the joe schmoe welds that you have done at a muffler shop but TIG welds are the ones that most manifold/dp/exhaust companies use on performance items.
I'm in the same boat as you. I don't know that much about welding and I'm contemplating about buying a nice welding machine. Check out http://www.fab-forum.com when you get a chance.
Old May 30, 2004 | 09:35 PM
.Ash's Avatar
i had a miller syncrowave 350, but after a while noticed that running it in my garage wasnt the best idea. i then got a new lincoln presicion 185 tig, and have been pretty happy with it. paid ~$1700 for it shipped new, and welds everything from fmic's to 1/4 plate fine.
Old May 30, 2004 | 10:08 PM
Joseph Davis's Avatar
Default Re: (Amallick)
Miller Synchrowave 250SD seems to be the smallest TIG worth buying. When I say that, I mean quality and ability. $1200 plus tanks and regulator rental/purchase.
If you wanted a MIG, with an eye to portability... Hobart Handler 135. It's the Miller unit repackaged in a plastic housing at a discount. Also, I've had some very good luck with lightweight "crap" MIG welders by running quality wire through them. The **** wire at Homeboy Depot or Blowes has no place anywhere except a trashcan, drive the extra two miles to the welding shop.
Old May 30, 2004 | 10:53 PM
hulkhb's Avatar
Default Re: (J. Davis)
Others here and myself favor the Miller 180SD (its a tig), hence it can do all the the price is awesome, I paid about $1,200.........and its well woth buying.
Old May 31, 2004 | 07:21 AM
Default Re: (hulkhb)
Hey guy
thanks for the fast replys. So what ive gathered so far is that a MIG is not what im looking for ... right? OR is is just that MIG welds arent quite as nice.
Old May 31, 2004 | 09:48 AM
Default Re: (nitekidsef9)
MIG welds aren't quite as nice, and to do aluminum with them you need a $$$ spool gun. You can't push feed aluminum wire without birdsnests ever two minutes.
Old May 31, 2004 | 07:46 PM
.Ash's Avatar
[QUOTE=J. Davis]Miller Synchrowave 250SD seems to be the smallest TIG worth buying. When I say that, I mean quality and ability. $1200 plus tanks and regulator rental/purchase.
QUOTE]
woah, 250 amp tig welder for 1200 new? link please!
vr6chris
Welding / Fabrication
Jan 18, 2005 08:39 PM
RACEPAK
10
Jan 14, 2005 01:45 PM
Heath
Jan 30, 2003 08:08 AM
