ID this LSD.
Old May 30, 2004 | 07:50 PM
brekekex's Avatar
Default ID this LSD.
Came out of a Y21 tranny.
I am not aware of Honda using a purely clutch activated LSD in any trannies.
Check the pics, and let me know what you think.
The diff.
Here is a pic of the diff opened up. Notice the hexagon shaft output.
Here is another with shim and washer removed.
And here is a closeup of the clutch discs and plates.
And this is a KAAZ clutch comparison, and the ones they compare theirs to, appears IDENTICAL to the ones in my LSD. Note the rounded outer tabs on plates, and the 12 point inner "splines" on the discs that fit the hexagon axle output.
And here is the side gear carrier... rounded on one side to load the clutch packs upopn acceleration, and stepped on the other to load the clutch packs under braking. I assume this is a 1.5 way LSD due to the different shape on the acceleration and brake side of the carrier.
So if anyone can identify this LSD, I would greatly appreciate it. I need to know what fluid to use with this, as I doubt honda MTF is compatible with clutches.
Thanks.
-Thomas
Modified by brekekex at 12:35 AM 5/31/2004
Modified by brekekex at 1:21 PM 6/6/2004
Old May 31, 2004 | 07:53 AM
machine4321's Avatar
did you buy that tranny ....or is it one your working on
Old May 31, 2004 | 09:00 AM
Kal's Avatar
Kal
Default Re: (machine4321)
I believe Honda did use clutch packed LSDs in their really early generation cars. But I recommend a fluid built for clutch types, i.e. - using kaza or spoon fluid will work since their lsds are clutch types.
Old May 31, 2004 | 09:08 AM
DaX's Avatar
DaX
Loved
Community Favorite
The Y21 came in the 96-97 USDM ITR's and had LSD's...but I thought they were gear type as well...
Old Jun 2, 2004 | 06:00 PM
so what was the outcome
is this a tranny you own ...or fixing it ....just curious cause my friend sent a tranny back to get looked at and it turned out to be a spoon drag lsd or so they told him
Old Jun 2, 2004 | 06:06 PM
y21 also came in the sir 2 and jdm delsol with opt lsd
Old Jun 3, 2004 | 02:00 AM
b00sted93Hatch's Avatar
I thinks its a cusco.
fjt
Dec 7, 2005 06:32 AM
alexdog69
Oct 5, 2005 08:09 AM
KFBhonda
Mar 4, 2005 02:48 PM
importboi22
Jan 24, 2005 10:24 AM
integranator
Nov 29, 2002 08:52 AM
