timing gear keyway/key problem please look
Old May 30, 2004 | 07:47 PM
tek_civic's Avatar
Default timing gear keyway/key problem please look
ok so my crank pully is messed up, not sure why or how but its being replaced. aftertaking that off i noticed that my crank keyway has some room in it, as in the locator pin is too small, i can actually fit an allen wrench next to the key while the pin is in and its on the crank. its hard to see in the pic but the dark area is what im talking about, there is a gap between the locator key and the side of the crank/gear. let me know what you think about this and to what extent of damage there could be.
ps im also having a hard time getting the timing gear off, any ideas?
Old May 30, 2004 | 07:58 PM
Dan GSR's Avatar
Default Re: timing gear keyway/key problem please look (tek_civic)
take the belt off to get the gear off
looks like the key is too small, get a new one
Old May 30, 2004 | 08:10 PM
tek_civic's Avatar
Default Re: timing gear keyway/key problem please look (Dan GSR)
yeah i hope that it is that easy. i will pick one up tomarrow. i just hope no damage to the crank has happend, i have heard of them getting messed up from stuff like this. more opinions welcome!
Old May 30, 2004 | 09:21 PM
tek_civic's Avatar
one more question. is the b18a crank timing gear one piece? i mean does it have a locator pin that is removable or is it all one piece with a built in pin? tnx
EDIT: NM i found out by reading someone else's horror story of a similar thing happening, i consider myself lucky that i found this before it sheerd off causing really bad problems. anyone know where to get a new timing gear? tnx
Modified by tek_civic at 11:44 PM 5/30/2004
Old May 31, 2004 | 03:53 PM
shaved4dooref's Avatar
u should get all the oil and greese out of the timing chain cover area. use some degreaser and what ever part u take off clean it well. i changed my timing belt and waterpump and clean every single part. looks clean
Old Jun 1, 2004 | 01:43 PM
tek_civic's Avatar
Default Re: timing gear keyway/key problem please look (shaved4dooref)
hey does anyone know if the timing gear i am talking about is the same as one on a b16? i assume it is but not entirely sure. anyone know where to buy one of these new? tnx
boostedteg4dr
Feb 25, 2014 08:39 PM
natebaur
Feb 13, 2010 10:58 AM
H22Luda720
Feb 13, 2006 06:37 PM
ActiveAero
Feb 3, 2006 07:10 PM
H22AJSPEC
Jul 16, 2003 07:38 PM
