Is it okay to use Synthetic gear oil?
I have a 94 honda prelude and i'm a lil worried about the tranny. I know in 94's it's bad to use synthetic motor oil for the engine, but does the same apply for the tranny? I doubt it but I just want to make sure. I want to make sure it's protected really good. Also what rating would I use? I see all these numbers on the gear oil 80W, 75W yadda yadda yadda. Which one do I use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro »</TD></TR><TR><TD CLASS="quote">It's not bad to run synth in the motor. But is in the tranny. You should use synchromesh MTF or Honda MTF. Not a heavy gear oil. </TD></TR></TABLE>
how is it bad ive have it in my car going on 4 yrs, mobil 1 10w 30
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specalk »</TD></TR><TR><TD CLASS="quote">
how is it bad ive have it in my car going on 4 yrs, mobil 1 10w 30</TD></TR></TABLE>
i think he's talking about the gear oil you use in a rear end. that stuff is way too heavy to use in the transmission.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mariowc »</TD></TR><TR><TD CLASS="quote">You don't use a gear oil in the tranny.
Use either 10w30 motor oil, or something like GM Syncromesh.</TD></TR></TABLE>
ya ive got moble 1 10w 30, ive never had any grinds 80k miles
haha you guys are full of misinformation..
yes you can use synthetic 75w90 in your transmission.. I just ordered Amsoil 2000 series for the tranny in my h23a1..
In some engines with excessive wear switching to synthetic motor oil might cause a little leakage, but will usually go away after a while.. Chances are you will be fine.
i use 85w140 in the rear end for my truck, but that stuff is too thick to even get into the prelude's transmission without some assistance.
Modified by del_parker at 6:57 PM 5/31/2004
the manual AND dealer recommend 10w-30 MOTOR OIL NOT gear oil. although you may be fine using 75w90 gear oil but if you want to put that much stress on your tranny that is up to you.
David
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn »</TD></TR><TR><TD CLASS="quote">haha you guys are full of misinformation..
In some engines with excessive wear switching to synthetic motor oil might cause a little leakage, but will usually go away after a while.. Chances are you will be fine.</TD></TR></TABLE>
What misinformation? Honda says to use 10w30. That's mis-info right there?
integra123
Oct 8, 2006 06:58 PM
hxtasy
Jan 26, 2005 09:45 AM
