smog time in socal
ok its about time for my smog and i need to pass .for one i know some of my vacuum hoses are wrong.and i have a aftermarket intake..i need some help with the vaccuum lines .cause i couldnt find a diagram about it. A sensor on the headers is not hook up and i dont have a harness to hook it up with
Heres my setup
b16a1 OBD-0
Aftermarket intake
stock cat and exhaust
what will i have to do to pass smog. need some tips you had to do.thanks in advance
Heres my setup
b16a1 OBD-0
Aftermarket intake
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEFnine1 »</TD></TR><TR><TD CLASS="quote">
what will i have to do to pass smog. need some tips you had to do.thanks in advance</TD></TR></TABLE>
please do a search.. this has been asked to death.
to do it right, you would have to get it bar'ed by california and have all smog devises from that car then engine came out of... a jdm b16.. good luck explaining that to the ref. also.. you need a valid vin.. explain to them where the engine came from also.
search for so cal smog.. its been hacked to death.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">first of all, your going to fail visual if the swap is not BAR legalized. </TD></TR></TABLE>
» Search Results
Your search for smog returned 110 results
Just do a search bro, it has been covered many times.
» Search Results
smelldaOdaa
Mar 25, 2006 04:24 PM
