Can you use tuner lugs with OEM wheels?
Old May 30, 2004 | 12:35 PM
Quik89Si's Avatar
Default Can you use tuner lugs with OEM wheels?
I know they will fit, but is it dangerous to do so?
I have a set of Muteki tuner lugs, and I'm wanting to put my OEM CRX Si wheels back on...but I don't have the OEM "acorn-style" lugs. Can I use the Muteki's, and what are the possible consequences of doing so?
Thanks guys.
Alex
Old May 30, 2004 | 12:51 PM
fourthgenhatchB17's Avatar
Default Re: Can you use tuner lugs with OEM wheels? (Quik89Si)
i know what you are talking about. I have done it many times before without any problems. Now, whether its advisable (safety wise) to do so or not, i dont know, but it does work and my wheels did not fall off
Old May 30, 2004 | 12:56 PM
Quik89Si's Avatar
Default Re: Can you use tuner lugs with OEM wheels? (fourthgenhatchB17)
Good to know, thanks for the info
Anyone else have experience with this?
Alex
Old Jun 6, 2004 | 08:46 PM
whitelightnin's Avatar
any other input?
Old Jun 6, 2004 | 10:55 PM
Tyson's Avatar
well having done this myself, youll dig a little ring around each of your lugnuts as it catches the inner edge of the stock wheels. especially since theyre aluminum. because of this, youre not going to get an accurate reading on the torque. but in my experience, the wheels stayed on, but honestly, i would just go to the junkyard and pick up a few pocket fulls of stock ones and do it right, and not have to worry about it.
Old Jun 7, 2004 | 04:19 AM
keithv's Avatar
Default Re: Can you use tuner lugs with OEM wheels? (Tyson)
I agree with what Tyson said.
Old Jun 7, 2004 | 12:59 PM
pyro_freak8's Avatar
you can get stock sized one's new from like oreily's or autozone, i personally think that would be better and much safer
Old Jun 7, 2004 | 01:03 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (pyro_freak8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_freak8 &raquo;</TD></TR><TR><TD CLASS="quote">you can get stock sized one's new from like oreily's or autozone, i personally think that would be better and much safer</TD></TR></TABLE>
I had to do this after snapping a few lugs. You can buy them indivually for just a couple dollars.
Old Jun 7, 2004 | 01:06 PM
APEX CRX's Avatar
miamihonda
Acura TL, RL & ZDX
Jan 26, 2015 05:30 AM
Adrian Peterson
Wheels
Jan 26, 2010 06:49 PM
Hatchback of Notre Dame
Jun 8, 2009 05:48 PM
Todd00
Apr 21, 2005 04:04 PM
