VTEC Nightmare!!!
Old May 30, 2004 | 12:33 PM
Gunns's Avatar
Default VTEC Nightmare!!!
Please help stop my VTEC Nightmare!!!
I have a 94 JDM GSR into my 92 Civic CX Hatch with a P72 A01 ECU. Vtec is not working and I am throwing code 21 (vtec solenoid). I ran a 12 volt power source to the vtec solenoid and it clicks so that works. I ran a wire from the ecu to the vtec solenoid so a short is ruled out. I unbolted the vtec solenoid and cleaned the screen. My oil pan does not have any dents in it. My oil is clean and up to the proper level on the dip stick. With the wire ran from the ecu directly to the vtec solenoid I reset the ecu and the code will go away and stay off until I bring the car up to 5500 rpm. Right where vtec should engage and then bang cel 21 in my face again.
I have searched almost every topic relating to this issue and I am out of ideas.
Please help!
Kurt
kurtgunnis@hotmail.com
Old May 30, 2004 | 12:42 PM
Tad's Avatar
Tad
Default Re: VTEC Nightmare!!! (Gunns)
sounds like its not wired up properly.
theres lots of posts on that here,
but there are 3 wires you have to run
Old May 30, 2004 | 12:45 PM
B_CRUZ!'s Avatar
double check the wires...
Old May 30, 2004 | 01:28 PM
Gunns's Avatar
Default Re: VTEC Nightmare!!! (b_cruz)
Thanks for the diagram, I have seen it before though. I have triple checked the wiring.
TAD: There is only one wire from the vtec solenoid. That is the code that I am throwing. As I stated earlier I ran a wire from the vtec solenoid to pin A4 on the ECU.
Thanks for the replies. Anyone else?
Old May 30, 2004 | 01:52 PM
thenick's Avatar
perhaps get a new spool valve filter and gasket
Old May 30, 2004 | 03:36 PM
redStorm's Avatar
Default Re: VTEC Nightmare!!! (ixiblindixi)
A new VTEC slnd could be the problem. However, I've had the same problem with a USDM P13 running my h22a. Turned out that the ECU was chipped and the chipped was messed up.
Gunns : open your ECU and checked if it was chipped already. I'ts kinda long shot but worth having a look.
Olivier
Old May 30, 2004 | 04:13 PM
B_CRUZ!'s Avatar
I went through the same BS as you and wasted many HT members time... my problem was the ecu being shitty. Try a friends ecu. Good luck.
Old May 30, 2004 | 04:47 PM
SprayinCX's Avatar
on my ls/vtec engine the vtec wouldn't engage and it turned out that my main bearings where bad and i had to have the bottom end rebuilt. then it worked prefect.
Old May 30, 2004 | 04:57 PM
NiiS's Avatar
Verify you have oil pressure. We banged our heads against the wall for a week only to find out the oil pick-up(inside the oil pan) was clogged. Also check the port to the solenoid as well, sometimes it can get clogged, too.
GL
Old May 30, 2004 | 04:58 PM
1700anddroping's Avatar
Default Re: VTEC Nightmare!!! (SprayinCX)
the oil pressure is what engauges vtec "oil pressure" oil pressure switch check it out.
Old May 30, 2004 | 05:03 PM
toolowsol's Avatar
Default Re: VTEC Nightmare!!! (1700anddroping)
are you sure your wire is tapped into the ecu properly? Hook a multimeter up to the wire coming out of the ecu, and drive around having a friend see if your getting a signal coming out of the ECU. If you didn't use stock honda wires and pigtails, you probably don't have a good connection.
Old May 30, 2004 | 08:29 PM
Gunns's Avatar
Thanks for the help! I am going to have a friend who knows a little more than me take a look at it on the weekend. I will keep you updated!
Kurt
Old May 30, 2004 | 09:35 PM
JDMlyfestyle's Avatar
id check the oil pressure on the car. i believe the engine has to have at least 55-60 psi of oil pressure to hit vtec. correct me if im wrong any one
Old Jun 1, 2004 | 11:15 PM
IVI's Avatar
IVI
Default Re: (JDMlifestyle)
correct on the psi
swizz977
10
May 25, 2011 08:15 PM
GSRHATCH619
12
Apr 2, 2008 03:48 PM
686_ef
12
Feb 13, 2006 08:31 PM
MugeNinja
Dec 29, 2005 09:50 AM
sk8phaze
Jul 28, 2003 07:44 PM
