B&M fuel pressure gauge, bolt question
Old May 30, 2004 | 11:48 AM
RCautoworks's Avatar
Default B&M fuel pressure gauge, bolt question
Can anyone tell me the size bolts the b&m gauge comes with, I have a gauge but no bolts came with it, I really need to know the side of the bolt that threads in to the fuel filter.
Old May 30, 2004 | 12:04 PM
Default Re: B&M fuel pressure gauge, bolt question (90blackcrx)
There circled in red.
Old May 30, 2004 | 01:20 PM
No one knows ???????
Old May 30, 2004 | 01:24 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The brass piece is standard pipe thread...
Size is 1/8-27 NPT
The bolt is 12mm x 1.25mm pitch..
Old May 30, 2004 | 01:27 PM
Default Re: B&M fuel pressure gauge, bolt question (88DXCRX)
Thanks Phil
Old May 30, 2004 | 04:00 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
the 1 90 is normal brass fittings, but the one between the gauge and the filter is hollow and male-female on one side... but its hollow to allow the fuel to come inthrough the banjo hose..
ive never seen these avail. other than in those kits.
Old May 30, 2004 | 04:30 PM
Default Re: B&M fuel pressure gauge, bolt question (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">the 1 90 is normal brass fittings, but the one between the gauge and the filter is hollow and male-female on one side... but its hollow to allow the fuel to come inthrough the banjo hose..
ive never seen these avail. other than in those kits.</TD></TR></TABLE>
Thanks Chris, I ended up ordering the b&m from summit so I will have the bolts. Now I just will have 3 gauges sitting around, I'll have to sell the 2.
Old May 30, 2004 | 04:38 PM
Built B16A's Avatar
no prob.. yeah, that bolt is uniqe. its hollowed to let fuel pass throughit.. if you put a bolt through it.. it woudl'nt flow.. at all.
if you wanted to take it a step further, you coudl hit up your local tunner store, and see if they can contact B&M, and get extra bolts.. thats if they like you. its worth a shot.
IE: ordering new replacement oil press. senders from autometer.
Old May 30, 2004 | 08:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">no prob.. yeah, that bolt is uniqe. its hollowed to let fuel pass throughit.. if you put a bolt through it.. it woudl'nt flow.. at all.
IE: ordering new replacement oil press. senders from autometer.</TD></TR></TABLE>
That would be worth a shot, but I need everything before Friday so I can tune these ITB's .
Old May 31, 2004 | 06:56 AM
Die-Laughing's Avatar
yeah..i had the same problem.
i purchased the marshall fpg and it came by itself..i thought it would come with some kind of adapter but..no.
so i found an extra banjo bolt and had my friend drill and tap it..for a 1/8 standard pipe thread to fit.
it was kind of a pain in the ***...i would recommend trying to get a "kit" when buying a fpg
BLinindoll
Dec 2, 2007 05:04 PM
jason_alt
Jul 8, 2005 03:12 PM
Savv
18
Apr 12, 2005 06:33 AM
X2BOARD
Apr 20, 2004 09:43 AM
essex
Mar 12, 2004 03:27 PM
