how to wire IACV to ecu??
im not sure if theres somthing with my wire harness but im stll throwing code 14 and i changed out iacv and changed plug to brand new one how do you wire this to the ecu? A9 is the pin out but which one is the one that goes there the red wire or the black n yellow??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morhpeous »</TD></TR><TR><TD CLASS="quote">im not sure if theres somthing with my wire harness but im stll throwing code 14 and i changed out iacv and changed plug to brand new one how do you wire this to the ecu? A9 is the pin out but which one is the one that goes there the red wire or the black n yellow??????</TD></TR></TABLE>
red wire and black/yellow? that is usually the Purge EVap sensor plug
blue wire and black/yellow..... is the IACV sensor plug
