Need help with Axles - grease everywhere
Old May 30, 2004 | 08:44 AM
youngvedder's Avatar
Default Need help with Axles - grease everywhere
Guys,
noticed on my front drivers side rim that it had a lot of grease on the inside of it, took it off and found large quantities of grease around the axle drive shaft boot. any oughts on what the problem is?
Wheel
boot with grease everywhere
another angle
any help greatly appreciated....is this something I can fix on my own? if not, what shoudl I expect to pay?
thanks,
YV
Old May 30, 2004 | 09:45 AM
tilt's Avatar
Default Re: Need help with Axles - grease everywhere (youngvedder)
your boot split. it's a relatively easy fix, just a huge pain if the axle is seized to the hub and/or separating the lower balljoint.
a couple options are:
replace the axle ~65$ autozone /w lifetime warranty
replace the boot, clean and repack with grease ~25$
either way you need to take the axle out.
Old May 30, 2004 | 09:47 AM
penney's Avatar
Default Re: Need help with Axles - grease everywhere (tilt)
make sure before you take on this project that you have access to airtools or a really strong friend
Old May 30, 2004 | 10:48 AM
Default Re: Need help with Axles - grease everywhere (97vtecGSR)
thanks guys......
YV
Old May 30, 2004 | 10:57 AM
HARI.'s Avatar
does it click when you turn, or make u turns. if it does you need to replace your axle.
Old May 30, 2004 | 11:27 AM
mrctr's Avatar
cv boot busted
Old May 30, 2004 | 11:29 AM
G-bonic's Avatar
Hijacked
YEA DOES IT MAKE SOUNDS WHEN U TURN IF IT DOES U GONNA HAVE TO CHANGE UR AXLE TOO AND PLUS HOW MANY AXLES ARE LIKE THAT IS IT ONE OR TWO? IF ITS ONE U GONNA HAVE TO PAY ABOUT 130 PARTS AND LABOR FOR EACH SIDE OF UR AXLE FOR BOOTS ABOUT 8 BUCKS.. IT DEPENDS HOW BAD U GOT IT.. U MIGHT WANNA GET IT DONE ASAP BEFORE IT COMES TO UR RACKIN PINION.. NOTE: UR CAR MIGHT BE TOO LOW THATS WHY ITS HAPPENING ITS GONNA KEEP ON DOIN THAT IF UR CAR IS TOO LOW .....
Old May 30, 2004 | 02:01 PM
Default Re: Need help with Axles - grease everywhere (Stock_LS)
it appears to the boot only, as I have not heard any noises from it. As for too low, I droped my car 1.5 so I don think its too much,,,
I will drive it straight to the dealer for repair.
Thanks,
YV
chris89
Transmission & Drivetrain
Aug 28, 2015 09:51 PM
RanCRX
Dec 28, 2009 03:03 PM
taimysho0
Jul 8, 2009 01:29 PM
ill phil
May 15, 2003 06:27 PM
AndyD
Jan 28, 2003 04:20 PM
