VTEC pressure valve CEL 22
Old May 29, 2004 | 06:41 PM
jetpilot's Avatar
Default VTEC pressure valve CEL 22
I recently did a mini me but just replaced my block for a ZC (SOHC) and kept my Z6 head (92 si). Now in 3rd gear at full throttle past vtec activation point (~5000rpm) I get CEL 22. Could it be that the ZC oil pump cant keep pressure at that load and rpm???? Im using my stock ecu (P28) and a stock P08 also and it does the same thing. Should I check the wires for some voltage or something (pin D6)?? Isnt there a hack that is to connect pin A4 to pin D6 and it works the same??
thanks
Old May 29, 2004 | 07:14 PM
Jaker's Avatar
Default Re: VTEC pressure valve CEL 22 (jetpilot)
Did you pull the oil control orifice out of the deck of the block before you put the head on?
Old May 29, 2004 | 09:55 PM
jetpilot's Avatar
yes. I dont think its a short cause its only in 3rd and 4rth when im at fulkl throttle
Old May 31, 2004 | 12:25 PM
jetpilot's Avatar
tt someone please help me identify
Old May 31, 2004 | 07:16 PM
jetpilot's Avatar
Does anyone know what oil pressureIshould see with a stock d16a6 oilpump and at what rpms? Also should oil pressure drop when vtec activates? how much of a drop
RinzEG6
Oct 14, 2014 03:34 AM
d1nki
May 10, 2008 12:23 AM
Mach69
14
Jan 8, 2006 12:13 AM
queez
Dec 18, 2004 04:32 AM
papa_smurf
Jul 28, 2003 12:03 PM
