Clutch help
Old May 29, 2004 | 05:54 PM
civic_hatchback's Avatar
Default Clutch help
My bro just got his new fidanza flywheel and exedy clutch in. When he goes to shift to 3rd at 8000 rpms he has a clutch grind. The clutch is brand new and he says it isnt a bad grind, it just doesnt go in easily. Can anyone help. Does he just have to break it in? Hes had it for 2 days. Thanks.
Old May 29, 2004 | 06:03 PM
mmuller's Avatar
Mad Scientist
Default Re: Clutch help (civic_hatchback)
sounds like a synchro, not the clutch
Old May 29, 2004 | 06:10 PM
Default Re: Clutch help (mmuller)
^^ What do i have to do to fix it, any cheap ideas?
Old May 29, 2004 | 06:15 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_hatchback &raquo;</TD></TR><TR><TD CLASS="quote">^^ What do i have to do to fix it, any cheap ideas? </TD></TR></TABLE>
you could try switching the tranny fluid to gm synchromesh to see if it would help temporarily.
but he's going to have to buy synchros and they are not cheap
Old May 29, 2004 | 06:19 PM
The thing is, he just got the clutch and flywheel in and his motor has never done that before. Where can i find some and who makes good ones. What exactly do they do?
Old May 29, 2004 | 06:39 PM
sporkcrx's Avatar
Are you sure the clutch is adjusted correctly? Maybe it's not disengaging all the way
Old May 29, 2004 | 06:42 PM
Default Re: Clutch help (sporkcrx)
Well my bro brought it to a shop cause he hasnt had the time to do it.....Its only after he shifts at 8k, when he shifts at 5 or 3 or 7 its fine....not sure, when i get down there we are gonna take a look at it. Anyone else?
Old May 30, 2004 | 08:08 AM
ACTman's Avatar
It sounds like an adjustment problem to me. It is pretty typical for a performance clutch to require a slight adjustment to get full release. What you want to do is raise the release point. I couldn't tell from your post if it is cable or hydraulic but either one is adjustable.
Old May 31, 2004 | 07:39 AM
Default Re: (ACTman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACTman &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like an adjustment problem to me. It is pretty typical for a performance clutch to require a slight adjustment to get full release. What you want to do is raise the release point. I couldn't tell from your post if it is cable or hydraulic but either one is adjustable.</TD></TR></TABLE>
It is cable. And we adjust it from where? You mean adjust the cable near the engine?
garyc17
Oct 28, 2006 12:05 AM
25Type-s
Oct 22, 2006 08:33 AM
f150harleytruck7
Dec 6, 2005 10:18 AM
92LudeSI
Apr 11, 2004 12:29 PM
