Rear Disc EX
Old May 29, 2004 | 05:12 PM
rsxts2003's Avatar
Default Rear Disc EX
I just swaped my 97 civic ex to rear disc but the e-brake cables dont work, so i thought about trying the ones off the car that i took the rear disc off and still no go. I took the rear disc off a 94 del sol, so i am out of option and no part store around here has NO CLUE WHAT THE HELL THEY ARE DOING. So if anyone has any ideas i could use the help!!!!!!!!!!
Old May 29, 2004 | 05:19 PM
JV's Avatar
JV
Who?
Default Re: Rear Disc EX (rsxts2003)
99-00 Civic SI cables?
Old May 29, 2004 | 05:22 PM
pdiggitydogg's Avatar
Default Re: Rear Disc EX (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">99-00 Civic SI cables</TD></TR></TABLE>
Old May 29, 2004 | 05:38 PM
VtecDeMoN's Avatar
Default Re: Rear Disc EX (pdiggitydogg)
99-00 Si or 94+ Integra...
Brian
Old May 29, 2004 | 06:35 PM
EricUSC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">99-00 Civic SI cables?</TD></TR></TABLE>
I'd go with these because they were made for the exact dimension of your car. These are what I use on my EX with rear disks.
Old May 29, 2004 | 07:19 PM
Sasebonian's Avatar
Default Re: Rear Disc EX (VtecDeMoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN &raquo;</TD></TR><TR><TD CLASS="quote">99-00 Si or 94+ Integra...
Brian</TD></TR></TABLE>
Yes, use these. I did my conversion from a del sol and the e brake cables were too short. That is because del sols have their own layout. The hang from right under the chassis suspended by the bracket, were as the civics and integras brackets are secured inside the car. You can just swap the cables out.
Old May 31, 2004 | 06:44 AM
rsxts2003's Avatar
sweet guys thanks
Old May 31, 2004 | 08:07 AM
FF DRFT's Avatar
I did rear disc out of a 92-95 Civic HB Si onto my 94 Civic EX 2dr, and the ebrake also hardly works. The cable is secured tho under the car. Is that my problem also? Need to use 94-01 Integra cable or 95 Civic EX cable?
Old Jun 1, 2004 | 08:52 AM
VtecDeMoN's Avatar
Default Re: Rear Disc EX (e1even)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e1even &raquo;</TD></TR><TR><TD CLASS="quote">I did rear disc out of a 92-95 Civic HB Si onto my 94 Civic EX 2dr, and the ebrake also hardly works. The cable is secured tho under the car. Is that my problem also? Need to use 94-01 Integra cable or 95 Civic EX cable?</TD></TR></TABLE>94-01 Integra cables. 95 Civic EX did not come with rear discs. I don't know if you'll be able to use 92-95 Si ebrake cables though? HTH.
Brian
Old Jun 1, 2004 | 09:01 AM
FF DRFT's Avatar
My friend's 95 Civic Ex had them. :-\ Maybe someone did a conversion on a stock Civic? Iono.
Old Jun 1, 2004 | 10:13 AM
kommon_sense's Avatar
95 civic ex w/abs came with rear discs.
I used the 99-00si e-brake cables on my 98ex.
Old Jun 1, 2004 | 10:40 AM
Sasebonian's Avatar
92-95 Civic EX Coupes had option for ABS/rear discs
92-95 Civic EX Sedans had standard ABS/rear discs
92-95 Civic LX Sedans had option for ABS/rear discs
92-95 Civic Si Hatch... I can't remember if it was standard or option
Old Jun 1, 2004 | 11:03 AM
137's Avatar
137
Default Re: Rear Disc EX (EricUSC)
where the **** did you get the rear brake conversion from? and why in the hell didnt you get the proper brake lines with it?
Old Jun 1, 2004 | 12:28 PM
FF DRFT's Avatar
Default Re: Rear Disc EX (137)
It was off a EG HB Si. They are the proper brake lines for that car. Why am I even wasting my time replying to you lol?
Old Jun 1, 2004 | 12:32 PM
137's Avatar
137
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e1even &raquo;</TD></TR><TR><TD CLASS="quote">It was off a EG HB Si. They are the proper brake lines for that car. Why am I even wasting my time replying to you lol?</TD></TR></TABLE>
Good question, no foul then... Play ball!
Old Jun 10, 2004 | 04:01 PM
rsxts2003's Avatar
sweet you guy kick ***, i go the cables for a 99 si and they work perfect. Thanks again, because i dont know anything more annoying than no ebrake but that might just be me.
Papichulo1767
May 24, 2013 02:49 AM
gabbernaut
Aug 22, 2012 10:58 AM
CivicSIR95
Jul 22, 2006 11:33 AM
swifty4u
18
Sep 15, 2005 02:42 PM
eK9aT10pSi
71
Feb 7, 2005 12:25 AM
