B20VTEC dowels
Old May 29, 2004 | 03:50 PM
Pandahatch's Avatar
Default B20VTEC dowels
I'm trying to go a different route putting my motor back together and I'm decidiing between dowel pins. I have the GE pins and they are a good idea, but you have to open the headgasket to fit them in the block. With the OEM pins you have to drill the head but you don't have to mess with the gasket. What does everyone use or reccommend? I'm thinking my leak might have something to do with this. Also what headgasket is everyone running? I've used GE and OEM B20B and have had the same problem.
Modified by PandaHatch at 1:23 AM 5/30/2004
Old May 29, 2004 | 07:44 PM
Pandahatch's Avatar
TTT
Old May 29, 2004 | 08:19 PM
torr's Avatar
Default Re: (PandaHatch)
i used a oem b20 headgasket and moved and drilled the dowels. no problems
Old May 29, 2004 | 10:42 PM
Pandahatch's Avatar
Default Re: (torr)
It's just really pissing me off, no matter what I do it leaks. I'm gonna try using the OEM head bolts.
Old May 30, 2004 | 08:43 AM
dfoxengr's Avatar
you shouldnt really reuse rod bolts. id stick with the GE dowels and an OEM HG
Old May 30, 2004 | 09:59 AM
Pandahatch's Avatar
Reuse rod bolts...? Huh I don't know where this came in. I have new OEM GSR HEAD bolts.
Old May 30, 2004 | 01:07 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch &raquo;</TD></TR><TR><TD CLASS="quote">It's just really pissing me off, no matter what I do it leaks. I'm gonna try using the OEM head bolts.</TD></TR></TABLE>
thought u were talking about the old ones.
Old Jun 5, 2004 | 09:17 PM
bull2k4's Avatar
Default Re: (hybridvteceg)
i just got finished building my b20vtec....moved up from an lsvtec. i used the ge dowels with arp head bolts and the cometic head gasket for a b20 same as oem b20 head gasket but it's 85mm bore....so for you the oem b20 gasket should work great..
ev94eg
Sep 29, 2011 09:24 PM
95LSv
Honda Civic (2001 - 2005)
Feb 22, 2011 09:52 PM
skiracer8148
Mar 16, 2007 09:56 AM
invisible
Feb 3, 2007 01:20 PM
