valve spring install with head on, droped piece
Old May 29, 2004 | 03:48 PM
slipstreamsi's Avatar
Default valve spring install with head on, droped piece
Hey guys, well while i was trying to install my springs and retainers, one of the small pieces holding the springs on fell into one of the holes. anyone know how i can get this out without taking off the head? Thanks.
Old May 29, 2004 | 05:47 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: valve spring install with head on, droped piece (slipstreamsi)
Which hole did it fall into? There are lots of little nooks and crannies in there.
Do you have that tool (I don't the name), where it's a long flexable rod with a pretty strong magnet on the end of it?
Next time put tape over the "dangerous" holes in the head.
Old May 29, 2004 | 05:54 PM
Code Blue's Avatar
Default Re: valve spring install with head on, droped piece (shamoo)
get a magnetic pick up tool, available at most hardware stores and any sears, you can find them with either a retractable ridged neck or the flexible neck
Old May 29, 2004 | 05:57 PM
gundamgsr's Avatar
as long as the piece isnt aluminum or titanium.
Old May 29, 2004 | 06:04 PM
Tweakmeister's Avatar
Default Re: (gundamgsr)
keeper?
probably fell to the oil pan...no need to take off the head.
Old May 29, 2004 | 06:14 PM
lke2drvgsr's Avatar
Default Re: (Tweakmeister)
omg dude that sucks, that happened to a guy on team-integra a few months ago when he was installing some crower's... we ran a shitload of oil through the motor to push the piece down into the oil pan then he took it to the shop and they got the piece out and installed the cams and stuff for him.. sorry to say but you're fucked go to a shop..
Old May 29, 2004 | 06:23 PM
NightmareApex's Avatar
Ummmm.. Ummmmm.. well hate to say it but the do it yourself attitude is kewl and all but it will cost you more money and down time in the end. My advice would be to take it to a shop and let them deal with the problem. if not you may never find it and in your quest to save a few hundred you may just make mroe and more problems for yourself. From what I can remember though I havent heard of anyone installing valve spring without taking off the head, infact I havent even heard of anyone installing valve springs short of a machine shop, but... what do i know I just know how to G turns so
Old May 29, 2004 | 06:33 PM
Default Re: valve spring install with head on, droped piece (NightmareApex)
the keeper fell into one of the wholes in between the 2 springs... not really sure where it leads... if i just keep putting oil in and draining it will it eventually go through to the oil pan? I dont wanna take it to a shop either cause no one near where i live will install them for me for less the 900$ and i dont have that kind of money right now.
Old May 29, 2004 | 07:29 PM
I think i've solved the problem, thanks for all the advice.
Old May 29, 2004 | 07:36 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slipstreamsi &raquo;</TD></TR><TR><TD CLASS="quote">I think i've solved the problem, thanks for all the advice. </TD></TR></TABLE>
You "think"? Better make sure before you crank that motor.
Old May 29, 2004 | 11:38 PM
Stripped Honda's Avatar
99-0104
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightmareApex &raquo;</TD></TR><TR><TD CLASS="quote">Ummmm.. Ummmmm.. well hate to say it but the do it yourself attitude is kewl and all but it will cost you more money and down time in the end. My advice would be to take it to a shop and let them deal with the problem. if not you may never find it and in your quest to save a few hundred you may just make mroe and more problems for yourself. From what I can remember though I havent heard of anyone installing valve spring without taking off the head, infact I havent even heard of anyone installing valve springs short of a machine shop, but... what do i know I just know how to G turns so </TD></TR></TABLE>
if you only call mechanic when you gotta work on your car then you will never learn anything if you atleast try then (even when something goes wrong) you will come away with the knowlege of how to do that job correctly ...
try the magnet if that doesent work then you may have to pull the oil pan and use something like a coat hanger or a wire to push the keeper down to the oil pan so you can remove it ..... good luck
Old May 30, 2004 | 09:21 AM
jh4db536's Avatar
Ouch, valvekeeperz PwNed u
drop the oil pan and windage tray and leave it off until u finish with all 16 springs.
put magnets or put a rag in the holes.
Old May 30, 2004 | 09:38 AM
tilt's Avatar
i dropped a keeper through one the oil drain hole before. had to take the oil pan off. after that i plugged all the holes and whatnot.
Old May 30, 2004 | 09:56 AM
Default Re: valve spring install with head on, droped piece (tilt)
well i started to take off the oil pan and get pretty far until i got to the last 2 bolts near the passengers side of the car. Anyone know how to get those 2 off?
Old May 30, 2004 | 10:02 AM
tilt's Avatar
you might have to take the flywheel cover off... i dont remember if i did or not. there are 2 metal brackets held in with 14 and 12mm bolts that you have to take off to get the flywheel cover off.
Old May 30, 2004 | 06:07 PM
got it out of the oil pan and got my springs and retainers on, now all i need to do is get that stupid bolt of the cam holding on the cam gear.... thanks for all the advice.
aznej2
Nov 21, 2006 02:12 PM
D50boy
Feb 24, 2006 06:56 AM
KoRE
Mar 13, 2003 06:42 PM
jabroni95gsr
Nov 19, 2002 08:17 AM
StinkyTofu
Feb 15, 2002 05:46 AM
