what do i hook this plug to? (pic inside)
Old May 29, 2004 | 02:10 PM
regime's Avatar
Default what do i hook this plug to? (pic inside)
i was cleaning up the wiring on my crx dx with an si swap into it. and i came across this plug with just a loose wire coming out of it. i was wondering if anyone could tell me what i hook it to.
also the guy i bought the car from had the fan plugged into a bunch of wires that ran loose into the passenger compartment like he was going to run it to a manual switch. i was wondering what i hook that up to also. thanks for ne help guys.
Old May 29, 2004 | 02:15 PM
EG8R's Avatar
Default Re: what do i hook this plug to? (regime)
One or two wires from it?
Old May 29, 2004 | 02:16 PM
sporkcrx's Avatar
Default Re: what do i hook this plug to? (skelly ed666)
02 sensor??
Old May 29, 2004 | 02:26 PM
regime's Avatar
ahh i bet yer right about the o2 sensor. since i still need to put a header on it =D thanks guys
any idea about were i wire the fan to now?
Old May 29, 2004 | 03:25 PM
sporkcrx's Avatar
Damn I'm good
Old May 29, 2004 | 03:50 PM
POORmansHATCHBOX-t's Avatar
yeap, thats your secondary O2 sensor
Old May 29, 2004 | 04:33 PM
crxgator's Avatar
Default Re: (b16rexinator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16rexinator &raquo;</TD></TR><TR><TD CLASS="quote">yeap, thats your secondary O2 sensor</TD></TR></TABLE>
secondary? we only have one...
Old May 29, 2004 | 05:48 PM
projektCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by regime &raquo;</TD></TR><TR><TD CLASS="quote">1
agreed on o2 sensor.
as for the fan. i have a obd1 ls block. with the d16a6 block. theres thermosensor on the block. for the obd1 ls block, there is no thermosensor, its located on the radiator. so what you can do. is wire tap the thermosensor wires or just connect them, but if u do that, ur radiator fan runs constantly, i didnt want to burn out my fan so fast, so i wired a switch to it. hope that helps..
Old May 29, 2004 | 06:05 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
secondary's are only on B16's
Old Jun 1, 2004 | 02:10 PM
regime's Avatar
Default Re: (Built B16A)
got it all done.... shoulda just started pokin arround b4 i bothered posting and asking. thanks all =D
fragmare
Sep 4, 2013 02:21 PM
masijdm
19
Jun 18, 2009 02:45 PM
Ritchie
25
Apr 27, 2007 01:17 PM
neonphire8604
Aug 8, 2006 08:00 PM
98teg
May 10, 2004 09:21 PM
