bottom end
Old May 29, 2004 | 12:20 PM
93_hatch's Avatar
Default bottom end
i was at the junk yard to day i found a d16a6 bottom end and a d15b7 bottom pistons and crank and all this would be working with a d16z6 going for a n/a maybe n2o later
i was wondering what would be a good street/strip set up on pump gas, whole block with z6 head or pistons(a6 10.4ish, b7 11.2ish) and what rods?
also are all the cranks the same or if i used one of them would i get a lil longer or shorter stroke? just thinking maybe i would get a crank balanced and blueprinted with out down time
thanks
Old May 31, 2004 | 06:22 PM
93_hatch's Avatar
Default Re: bottom end (93_hatch)
any input ppl....
Old Jun 1, 2004 | 05:41 PM
93_hatch's Avatar
Old Jun 1, 2004 | 11:19 PM
civicsitek GanGsTa's Avatar
z6 block, a6 or z6 crank (which ever is in better shape, polish it), a6 rods and pistons, z6 head. Done. 10.5:1 a nice exospeed stg 3 cam and some crower springs and you got a peppy d.
Old Jun 2, 2004 | 05:57 AM
85Trueno93Civic's Avatar
Mixing and matching to much can get dangerous. You can run into problems with valve clearance issues and water and oil line issues. But it is a little rare, so if you go for it let me know.
Old Jun 3, 2004 | 12:44 PM
93_hatch's Avatar
Default Re: (85Trueno93Civic)
okay... will do have to get some time off and go back and get them
Txdragon
Engine Machining & Assembly
14
Feb 10, 2018 04:53 AM
cityofcaterpillars
Dec 18, 2017 06:14 AM
j0keefe21
11
Oct 5, 2009 08:30 PM
projectef
Apr 29, 2007 08:16 PM
PhatHardy
Mar 3, 2003 07:43 PM
