Clutch Adjustment
Old May 29, 2004 | 12:16 PM
ineedmoney's Avatar
Default Clutch Adjustment
I just bought a 1988 honda crx Si. The bite point on the clutch is right at the very end ( all the way out). If any body could help me adjust it so that it is about half way through the stroke, or if I have to get a new clutch. Any imput would b sweet.
Old May 29, 2004 | 12:33 PM
tilt's Avatar
Default Re: Clutch Adjustment (newrexowner)
there is a plastic **** you can turn to adjust it. it's in front of the tranny.
Old May 29, 2004 | 03:47 PM
ghost_ryder35's Avatar
Default Re: Clutch Adjustment (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">there is a plastic **** you can turn to adjust it. it's in front of the tranny. </TD></TR></TABLE> its on the clutch cable. I do belive you want to tighten it so <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newrexowner &raquo;</TD></TR><TR><TD CLASS="quote"> it is about half way through the stroke </TD></TR></TABLE>
Old May 29, 2004 | 05:23 PM
blah13's Avatar
Default Re: Clutch Adjustment (ghost_ryder35)
Pull up on the arm, while holding it up tighten the **** down. See if you like it, if not loosen it a turn at a time until you find where you want it.
Old May 29, 2004 | 05:34 PM
projektCRX's Avatar
Default Re: Clutch Adjustment (blah13)
yep...just the adjustment ****.. mine clutch feels a tad bit wierd wit the swap..
Old May 30, 2004 | 07:42 AM
ineedmoney's Avatar
hey ghost rider what arm are u talking about, the actuall clutch pedal arm or is there one under the hood that u are refering to. Thanks for the help boys
Old May 30, 2004 | 10:18 AM
mildly.interesting's Avatar
the arm the cable attaches to on the outside of the tranny...if you pull up on it, the adjustment wheel above it is a lot easier to turn..it takes the tension off the wheel
Old May 30, 2004 | 11:31 AM
EFSiR's Avatar
keep in mind that if you still have the old cable it may be time to change it. They do stretch!
Old May 30, 2004 | 07:55 PM
ineedmoney's Avatar
Default Re: Clutch Adjustment (EFSiR)
right on man thanks for that, it seemed to have worked, but I think my clutch might just b on its last legs. this is the first time I have been in a forum, its sweet quick replys, hopfully I can b on the other end of it next time haha thanks again
Old May 31, 2004 | 12:21 AM
Quik89Si's Avatar
Helpful tip for me too, thanks!
Alex
Old May 31, 2004 | 08:53 PM
gen2integra2001's Avatar
Default Re: Clutch Adjustment (Quik89Si)
hey guys after i put on my built head on my 91 teg ls...the clutch dosent really grip to well wen i shiftat hi rpms as if im racing..do you think i can make it grip a lil better by adjusting the **** too?
Old May 31, 2004 | 10:14 PM
Rywire's Avatar
Default Re: Clutch Adjustment (gen2integra2001)
Adjust the arm to 1/8 inch freeplay. That is the adjustment spec, you dont want the throughout bearing ridding on the pressure plate splines. Ryan
crxricer66
Nov 14, 2007 03:15 PM
spoolin_teg
Jan 9, 2007 05:52 PM
RboYi
Feb 14, 2005 11:42 PM
90hatchie
Nov 10, 2004 12:04 PM
4DRmafia
Jun 10, 2004 06:58 AM
