Type R sway bar question
Old May 29, 2004 | 12:00 PM
dc2ali's Avatar
Default Type R sway bar question
can you use the stock gsr endlinks to install a jdm type r sway bar? and does anyone make any bushings that are better than the stock type r ones that will fit?
Old May 29, 2004 | 03:02 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: Type R sway bar question (dc2ali)
http://geocities.com/bretq/swaybar_install.html
Old May 29, 2004 | 04:59 PM
dc2ali's Avatar
Default Re: Type R sway bar question (integra707)
thanks integra707, do you know if that is for the jdm 23mm sway bar or if it is for the usdm 22mm sway bar? and do you think there is a big difference in the way the two perform?
Old May 29, 2004 | 05:15 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ali &raquo;</TD></TR><TR><TD CLASS="quote">thanks integra707, do you know if that is for the jdm 23mm sway bar or if it is for the usdm 22mm sway bar? and do you think there is a big difference in the way the two perform?</TD></TR></TABLE>
That site is for the USDM 22mm rear sway bar. I'm almost positive that you can use the stock endlinks. But you do need different bushings and brackets for the middle section.
Old May 29, 2004 | 08:39 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Type R sway bar question (shamoo)
&lt;- using stock endlinks on my ITR rear sway.
Old May 29, 2004 | 10:08 PM
dc2ali's Avatar
Default Re: Type R sway bar question (PatrickGSR94)
is there a big difference between the usdm and the jdm sway bar performance wise?
Old May 30, 2004 | 11:25 AM
dc2ali's Avatar
anyone???
Bbasso
Mar 3, 2008 07:16 PM
hamburgler
15
Feb 20, 2007 04:42 AM
jweezy225
Jun 15, 2006 04:14 PM
