93' H23 BLOCK / 96' H22 HEAD / STOCK HEAD BOLTS - MAX TORQUE THEY WILL HOLD?
Old May 29, 2004 | 11:33 AM
speedy108's Avatar
Default 93' H23 BLOCK / 96' H22 HEAD / STOCK HEAD BOLTS - MAX TORQUE THEY WILL HOLD?
I am curious as to what the max torque that I could apply with out haveing problems stripping the headbolt holes in the block out. The factory torque for the final round is 72ft-lbs. Could I go to 80 or 85 ft-lbs or more? Anyone had any experience with this matter?
Old May 29, 2004 | 04:20 PM
non-VTEC's Avatar
Default Re: 93' H23 BLOCK / 96' H22 HEAD / STOCK HEAD BOLTS - MAX TORQUE THEY WILL HOLD? (speedy108)
why would you want to exceed the torque specs on those stock bolts? that will only increse the possibility of head warpage/bolt stretch or gasket leaks.
get a set of ARP headstuds instead.
purestreetracer
Jan 11, 2010 10:13 PM
Varano44
Jun 27, 2008 08:55 PM
EGhatch22
Jan 15, 2005 11:06 PM
