Separating tranny fom block
Old May 29, 2004 | 11:07 AM
3.8turbo's Avatar
Default Separating tranny fom block
Whats the best way to separate the tranny from block? I removed all the bolts. Whats the trick to separating them?
Old May 29, 2004 | 11:39 AM
LSpimpTEC's Avatar
Default Re: Separating tranny fom block (3.8turbo)
dead blow hammer...give it a couple taps. is the engine still in the car? its a lot harder that way. other than that you just have to work at it
Old May 29, 2004 | 11:52 AM
blapblap!!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.8turbo &raquo;</TD></TR><TR><TD CLASS="quote">Whats the best way to separate the tranny from block? I removed all the bolts. Whats the trick to separating them?</TD></TR></TABLE>
it should come off with no problems.. almost fall off by itself... starter out??? just double check all the bolts that mount the tranny to the motor
carlos8
Sep 30, 2013 11:47 AM
totsie7944
Feb 4, 2008 08:34 AM
Tony_EM1
Nov 2, 2005 08:04 PM
navin
Mar 18, 2002 11:28 AM
Mario
Mar 15, 2002 07:36 PM
