What kind of glue or sealant do i use for a speaker box?
Old May 29, 2004 | 10:55 AM
initialvtec's Avatar
Default What kind of glue or sealant do i use for a speaker box?
I just made a custom box for my jl 12w3v2. I need to know what kind of glue or sealant to use to go over the cracks inside the box? Or do i not need to? I also heard that when you put the sub in the box you should seal around the sub with glue also, so air won't get out? HELP!
Old May 29, 2004 | 11:07 AM
debogsr's Avatar
Default Re: What kind of glue or sealant do i use for a speaker box? (initialvtec)
Use silicone sealent you can buy from any hardware store. Anyone will work. It is wise to silicone around the sub if you think there could be any air gap. Whatever you need to do to make it airtight. Sometimes the sub on the box can make its own seal tho, so its whatever you think u need to do. good luck and post pics up of the box u made.
Old May 29, 2004 | 12:15 PM
Default Re: What kind of glue or sealant do i use for a speaker box? (debogsr)
thanks! Do i need like some sort of glue gun or something? Actually i had my friend make it in his shop class. It's the exact measurements to the JL specs . The fry's box i was using did not sound good at all! Here some pics..
Old May 29, 2004 | 12:18 PM
debogsr's Avatar
COol man, that looks really good. You can buy the silicone and use a caulking gun, or you can buy it in a tube(what i did). The tubed stuff is a little more easy, but its super easy to work with. What are you going to cover the box with? That will sound awesome!
i'm debating if i should carpet it or not, i know i'd probably do a crappy job if i did.. and i'm kinda lazy to do it lol.
Old May 29, 2004 | 12:19 PM
debogsr's Avatar
seriously, carpeting it is really easy. If your careful making your seems connect nice it will turn out beautiful. If you need instructions on how to cover, i can help. I covered mine with vinal and it turned out pretty nice.
the tubed stuff is a lot smaller right?
Old May 29, 2004 | 12:20 PM
debogsr's Avatar
yes
nice! Got any pics?
Old May 29, 2004 | 12:21 PM
debogsr's Avatar
yep here ya go https://honda-tech.com/zerothread?id=868739
Old May 29, 2004 | 12:24 PM
looks really good! I guess i will carpet it then.
Old May 29, 2004 | 12:26 PM
debogsr's Avatar
Thanks, yeah just use wood glue, and be careful with the seems. good luck!
Old May 29, 2004 | 12:28 PM
thanks a lot man!
Old May 29, 2004 | 12:35 PM
debogsr's Avatar
no prob, pm me if u have any questions, and pm me also when u finish to show me pics. Later
Old May 29, 2004 | 12:36 PM
will do
Old May 29, 2004 | 02:09 PM
renone's Avatar
liquid nails
between each jount then screw
and then run a bead around inside and out
Old May 29, 2004 | 02:32 PM
Auex's Avatar
Default Re: What kind of glue or sealant do i use for a speaker box? (renone)
I glass the inside of every one of my personal boxes.
Old May 29, 2004 | 03:45 PM
Default Re: What kind of glue or sealant do i use for a speaker box? (Auex)
ahh i saw liquid nails there, but it didn't say silicon soo i didnt' get it. I got silicone 2 stuff, how do you glass out the inside?
Old May 29, 2004 | 06:14 PM
Auex's Avatar
Fiberglass resin, just mix some up and pour it in.
Old May 29, 2004 | 06:51 PM
debogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auex &raquo;</TD></TR><TR><TD CLASS="quote">Fiberglass resin, just mix some up and pour it in.</TD></TR></TABLE>
never thought of that, good idea
crazyboy
Audio / Security / Video
17
Nov 2, 2009 08:45 AM
hometheaterman
10
Jun 19, 2009 05:25 AM
CrazyModGSR
Jul 15, 2004 08:21 PM
loki2323
Nov 10, 2003 12:06 AM
GoLowDrew
Jul 17, 2001 09:36 PM
