reassembling B16
Old May 29, 2004 | 10:53 AM
Pete_SI's Avatar
Default reassembling B16
To assemble the crank pulley to the crank do you have to align both notch on the pulley and the crank. Also I would like to know the the torque specs for b16.
Old May 29, 2004 | 11:05 AM
Two_K Si's Avatar
Default Re: reassembling B16 (Pete_SI)
You need a HELM shop manual. PM me and i wil hook you up with a site that has them.
Old May 29, 2004 | 11:18 AM
Pete_SI's Avatar
Default Re: reassembling B16 (Two_K Si)
I don't have time to get a HELM manuel I need it now.
Old May 29, 2004 | 11:45 AM
Two_K Si's Avatar
The helm shows that you do not have to line up anything. Torque the bolt to 130 lbf-ft. Make sure that you lube the thrads onthe bolt, and remove any oil from thr mating surfaces of the pulley, timing belt guide plate, tiing belt drive pulley, and the crank.
Old May 29, 2004 | 01:05 PM
Pete_SI's Avatar
How do I know where's TDC.
Old May 29, 2004 | 02:09 PM
kyosoeg6's Avatar
man if u dont know that u have no business taking apart or trying to assemble a motor.
TDC is when piston # is at Top Dead Center. if u dont know which piston is #1 then i suggest u take ur block to a machine shop and pay themfor the work
Old May 29, 2004 | 04:28 PM
Pete_SI's Avatar
Default Re: reassembling B16 (kyosoeg6)
I know all of that but can I only look at the piston and when it's at the top i's TDC. There's a mark on the pulley and block that tells TDC and if you don't put the crank pulley the same way how can I say TDC.
Old May 29, 2004 | 05:50 PM
speedfreek128's Avatar
you have to line up the slots in both the crank and crank pulley because you have to put a woodruff key in there to keep the pulley from moving out of alignment
Old May 29, 2004 | 08:04 PM
Pete_SI's Avatar
Default Re: reassembling B16 (speedfreek128)
Thank you very thats exactly what I was looking for.
j4s0n1337
May 25, 2011 01:35 AM
BLKFLSH
Apr 10, 2011 01:54 PM
pokemon
May 20, 2003 08:38 AM
Tommy_Gunns
Jul 18, 2002 06:14 AM
Milano97
Jun 2, 2002 04:59 PM
