Rattling @ 2500 RPM
Old May 29, 2004 | 08:06 AM
JMcMusicman's Avatar
Default Rattling @ 2500 RPM
Stock 98 Civic LX 92K
I'm hearing a loud rattling noise coming from the engine right @ 2500 RPM
Any ideas?
Old May 29, 2004 | 09:12 AM
b16ahybrid's Avatar
Default Re: Rattling @ 2500 RPM (JMcMusicman)
could be any loos bolt,bracket,nut,washer,shield,etc....what mods have you done?
Old May 29, 2004 | 09:18 AM
AlekSir's Avatar
Default Re: Rattling @ 2500 RPM (b16ahybrid)
hmmm engine mount may be bad and causeing rattle but I doubt that
heat shield
where from engine,.???
Old May 29, 2004 | 12:09 PM
pro547's Avatar
I have the same problem. I think mine is the cat though.
Old May 29, 2004 | 02:24 PM
Default Re: (pro547)
Mine Could be the cat, although it's hard to tell where the noise is coming from.
No mods, completly stock. Nothing obviously loose, and only happens right @2500-2700 RPM. Also seems to get worse when the engine is warm.
Thx
Old May 29, 2004 | 02:45 PM
amy's Avatar
amy
Default Re: (JMcMusicman)
if it was the heat shield it would rattle when you're at idle also..... and not just in between 2500 - 2700 .... mine rattles at idle... when shifting.... and at higher rpms
Old May 29, 2004 | 03:06 PM
saboteurEK's Avatar
I think my cat rattles @ 1500rpm
Old May 29, 2004 | 04:56 PM
xASAPx's Avatar
probably exhaust maybe catylatic converter?.... heat shield would rattle on start... ?
DaveHoFoSho
Mar 7, 2009 07:05 PM
Integgin
Feb 19, 2005 04:19 AM
crxtreme27
Apr 10, 2003 06:16 PM
LOWLIFEHATCH
Dec 11, 2002 01:03 PM
Ideal R
Dec 28, 2001 11:37 AM
